2.73 Posi to 3.42 Open?
I finally have the time to put into my 89 IRoC this spring/summer which I haven't driven since 2012, thank you very much Mr. Military.
Currently my car has a 305, 700R4, long tube 3" headers, with a 26 spline 2.73 Posi diff and drum breaks. I have the option of purchasing a 4th gen rear with disc breaks & 3.42 diff, 28 splines but it is Open and not Posi.
I was wondering if that would be a worthy upgrade even though it is not Posi? I'm not looking to invest a ton of money into a after market rear, I would just like to slowly upgrade parts as I go. Eventually I'd like to have a 383 but my rear is the first item I'd like to upgrade/change.
Is gaining the gear ratio, 28 splines and disc breaks suitable for a future 383 or should I just hold onto my 26 spline Posi until I can afford a decent after market?
Thanks.
Thanks.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: 2.73 Posi to 3.42 Open?
yea ill say do it if its a great deal your gaining gearing and disc brakes
if your just driving and not aggressive driver you wont notice a difference
you can score posi Zexel from junk yard at times and classifieds ls1tech or on here
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Riwe, I have a 26 spline posi with 3.42 gears if you are interested.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
#1 learn to spell brakes properly
#2 I'd keep the posi. Have any of you driven an 85 or 86 IROC or Z28 with a LB9 and 3.23 or 3.42 open diff? They are a one wheeled smoke show much of the time, especially the 85s with 215hp. As much as the 2.73 sucks, I'd keep it just for the limited slip. You can get a used 3.42 gear set really cheap and you're going to have to buy a limited slip differential anyway, I'd keep the 2.73 posi.
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
fourth gen with 3.42 is probably a posi - if its a torsen unit when doing the posi test of turning axle it acts like single track 3.42 IIRC only came with 6 speed cars- I'd bet it has a torsen unit in it - no loss of posi and it will wake up your car very well
99 and later rears are torsens 98 and older were Auburn's which when worn out they're junk
Engine: 305 to 350
Axle/Gears: 10 Bolt
all v8 cars had posi if I'm not mistaken 3.42 was option in autos and standard on manuals
I could be wrong
if you get a open for a steal can find a Zexel aka torsen aka gear type posi to drop in for cheap
or clutch type posi for cheap as well now dollar for dollar get the posi rear over open but if you
don't care about one wheel burn outs autocross or drag then it doesn't matter really get what
fits your budget and needs
like he said above avoid the auburns there is one company in Australia I believe
that rebuilds them and sell parts for them
Sorry Zach, you are mistaken.
MANY V8 cars came without posi.
But as someone pointed out earlier, it's a piece o cake to install a posi. Go ahead and get it, and look ahead toward acquiring a posi for it.
MANY V8 cars came without posi.But as someone pointed out earlier, it's a piece o cake to install a posi. Go ahead and get it, and look ahead toward acquiring a posi for it.
Engine: 305 to 350
Axle/Gears: 10 Bolt
For 4th gen Camaro’s ? We are talking about right or referring to 3rd gen
I’m speaking about 98-2002 rear ends in 4th gen
for the LT1 I believe z28 and ss all had posi
Base z28 possibly had open don’t quote me
V6: all manuals 3.23 open or posi, auto is 3.08 open diff, 3.42 posi.
V8: all manuals 3.42, autos 2.73 or 3.23 all of them posi
98 had Auburn’s and 99+ had Zexel but I believe slp had Auburn’s
and thus far from junk yard only opens I seen have been v6
i could be wrong tho but that’s my understanding of it from notes I saved
Engine: 305 to 350
Axle/Gears: 10 Bolt
also if your know if car is a v8 sometimes it can act as a open diff aka worn auburn and with Zexel it can act as a open at time when trying to turn wheel
best way is to open diff cover and visual check people assume that both wheels turn and that's not always the case
3.42 open should of came out of a v6 manual car to OP
Car: 89 Firebird
Engine: 355 TBI
All 4th gen V8 cars had a 5.7 and a posi. Thirdgens should have went that route. 5.0s should have never been in these cars imo.
Engine: 305 to 350
Axle/Gears: 10 Bolt
seen very few
then there was the 9 bolt as option and all had auburn type posi
but with 4th gens the performance improvement and wanting better handling car was the addition of posi as a standard option on v8 and option on auto v6 depending on options equipped
and sense then have been standard option on 5th 6th gen v8 and manual v6 and I believe option on auto v6
Car: 89 Firebird
Engine: 355 TBI
Nine bolts are far superior to the Auburn but a cone style instead of clutch style. When u wear em out its hard to find parts for the Aussie 9bolt. They did hold up pretty good in third gens though. I think 89-90 was last year they run 9 bolts.
BLACK Z
Carburetors
16
May 16, 2019 04:34 PM
327_TPI_77_Maro
Apr 24, 2005 11:47 AM
Night rider327
Dec 20, 2002 11:40 AM
