Recommend a Clutch
Old Aug 2, 2019 | 12:34 AM
duponte's Avatar
Recommend a Clutch
Hi Y'all. I've got a mild 355 with vortec heads going into my 1989 Bird and behind it is going to be a fresh 2.95 geared WC T5. For the rear gearing i am going with 3.90 gears in a 9 Bolt. I'm just not sure what clutch i should put in that will last me a decent while, be fun to pound the street with and not give the trans a harder time than necessary. I don't have a lot of experience with clutches and what brand is best so i would really appreciate some recommendations and/or feedback on what others have experienced.
Old Aug 2, 2019 | 08:08 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Recommend a Clutch
I have been happy with my spec stage 1 in a similar engine.
Old Aug 2, 2019 | 02:05 PM
duponte's Avatar
I have been considering that one along with the McLeod 75125 streetpro but, if I can, I would like a cheaper option.
Old Aug 2, 2019 | 04:11 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Sounds like something similar to factory would work. Either Luk (French) or Sachs (German) would work. Luk clutch kit on Summit is $100, includes disc, pressure plate, t/o bearing and pilot bushing.
Old Aug 2, 2019 | 10:33 PM
midias's Avatar
No matter what you get make sure you get a good TO bearing, I usually replace any I get with hays
Old Aug 3, 2019 | 12:41 AM
duponte's Avatar
I am doing this on a relatively low budget so I might buy the cheaper stock like clutch and just replace it down the road when it goes. I did however find the PERFECTION CLUTCH30005Skit and for about $115 from rockauto that might be the way to go.
Why so concerned with the TO bearing? Are most of them that come with the kits crap?
EDGE
Apr 11, 2015 05:56 PM
jagevileye21
Aug 26, 2009 08:16 PM
SDalt404
Aug 16, 2008 12:09 AM
My90Iroc
Aug 20, 2002 09:52 PM
87ROCZ
Aftermarket Product Review
Dec 8, 2001 07:50 AM
