10 Bolt questions
Old Aug 5, 2019 | 09:32 AM
Red86SS's Avatar
Car: 1986 Camaro Z28
Engine: '80-'84 2 bolt 305, 58cc heads, FBO
Transmission: 1990 700R4 w/shift kit & 2-4 servo
Axle/Gears: 3.73 Posi (GT4 G80)
10 Bolt questions
So i have a posi 1990 7.625 10 bolt that i'm putting 3.73s in and i cant figure out what size my new ring gear bolts are. The set i got from Motive Gear has a sheet that has a bunch of different bolt sizes on it. I have no idea what to torque the ring gear bolts to, i've found several different specs for them but i need some help. One site says 50-65 ft lbs, a second one says 90 ft lbs and the third site says 100-110 ft lbs
Old Aug 5, 2019 | 10:26 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Re: 10 Bolt questions
This is going off of memory, so take it with a grain of salt, but I'm pretty sure I did mine to 65 ft-lbs when I swapped in my Torsen.
Old Aug 5, 2019 | 11:24 AM
Red86SS's Avatar
Okay, thanks! I'll keep that in mind when it comes time to torque them down
Old Aug 5, 2019 | 12:19 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Call the company that you bought the parts and ask them the torque specs, better for warranty claims than the "I torqued it to what the google search said "
Old Aug 6, 2019 | 10:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '92 FSM states to use 89 ft/lbs to torque the ring gear to case bolts.
Note that these bolts are a left-hand thread.
RBob.
Old Aug 6, 2019 | 11:36 AM
topless87's Avatar
Car: 1987 IROC-Z Convertable
Transmission: 5 Speed BW T-5
Axle/Gears: 3.08 Posi
You'll need a "left handed" torque wrench......
Old Aug 6, 2019 | 11:52 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Actually that's not a bad comment.... I didn't think of it too I did my 1st rear end years ago that my " click" style torque wrench does not resister on left bolts... I had to get a beam style one for them..
Old Aug 10, 2019 | 07:58 PM
geardaddy's Avatar
Car: 66 chevyll
Engine: blown alcohol injected
ring gear bolts 65...........cap bolts 60
maroguy1
Mar 4, 2019 04:56 PM
Billgluckman
Brakes
Nov 8, 2018 07:45 AM
foney_email
Sep 10, 2002 03:05 PM
I Cant Think of Anything
Aug 28, 2001 06:14 PM
92 RSS
Dec 8, 2000 04:13 PM
