700r4 problem
Subscribe
Aug 6, 2019 | 11:28 PM
I have a 700r4 behind my stock 350 it was running fine with my old motor I put in a rebuilt one same block number same flex plate only thing that changed is the intake and carb went from a Quadra jet to a demon street carb trans will not shift into any gear besides 1 neutral and revers
Reply 0
Aug 7, 2019 | 07:32 AM
Re: 700r4 problem
Is the TV cable connected and properly adjusted? Is a TV geometry kit required for the new carb?
If the TV set up is all good then pull the governor, good possibility that the gear is stripped.
RBob.
Reply 0
Aug 7, 2019 | 09:42 AM
Re: 700r4 problem
I have one more spot for the adjustment to try and I looked for a geometry kit and havent found one for the overner can’t it go out so fast every when the trans was working with the old motor
Reply 0
Subscribe
