Differential - ability to spin when off the car
Old Sep 10, 2019 | 08:48 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Should a differential that is out of the car be able to spin the wheel studs/axle shaft in either direction? clock wise or counter clockwise?
I was looking at my long neglected J65 equipped 10 bolt diff last night, which is sitting on the floor on floor dollies, hiding in the corner and thought heh, I'll try to spin the axles, but moving them clock wise they didn't seen to want to spin. counter clock wise they easily spun. quickly gave up, it was late, time to go, and didn't want to have to wash my hands again.
Old Sep 10, 2019 | 10:22 AM
Re: Differential - ability to spin when off the car
Yes, if both axles and the pinion gear are free to turn, then it should turn equally easily both ways.
Old Sep 10, 2019 | 10:42 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks. guess I'll actually pull it out of the corner today and have a closer look. seems like I had tested this a while back so not sure why it would stop working all by itself just sitting there on the ground.
Old Sep 10, 2019 | 04:26 PM
LiquidBlue's Avatar
Transmission: MD8
i am able to turn free in both directions however if i push the yoke inward it is locking up/gets very hard to turn. also appears the yolk is further out than normal. bigger than normal gap between seal and end of yolk
Old Sep 10, 2019 | 04:28 PM
LiquidBlue's Avatar
Transmission: MD8
out when it turns good, 2nd photo is with it pushed in and doesn’t turn forward properly
Old Sep 10, 2019 | 04:43 PM
LiquidBlue's Avatar
Transmission: MD8
opened up cover, can see what is happening. the gears attached to yolk interfere with gears they turn with. (sorry diff dummy here). too much play? what causes the play?
Old Sep 10, 2019 | 05:23 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Not a diff master but that is a time bomb waiting to go off haha. Pinion nut not torqued correctly ? Crush sleeve\spacer? bearing? I just picked up a 4th gen diff off an SS. That big gap between the yoke and the diff housing should be not be there that's for sure.
Old Sep 10, 2019 | 07:22 PM
That's messed up with a capital F.
No wonder it's uninstalled and laying around in a scrap heap. It's hard to believe somebody drove something around long enough to trash it that bad. I bet you could hear it several blocks down the street. Or maybe, somebody took it apart, and just half-assed it back together. No way that can be used like it is though.
Old Sep 10, 2019 | 07:24 PM
LiquidBlue's Avatar
Transmission: MD8
what do you think the issue may be? the gears look good, nice and crisp. don’t think it was run this way.
Old Sep 10, 2019 | 07:39 PM
LiquidBlue's Avatar
Transmission: MD8
ok, i’m officially an idiot. the yolk bolt was loose. i got this years back, maybe i loosened it for some reason. too many things going on since that time to remember and i didn’t take notes like i have since learned to do
Old Sep 10, 2019 | 08:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Looks like the pinion nut is loose. You can tighten it up but you need the correct preload on the pinion bearings and correct rotational tq.
Old Sep 10, 2019 | 08:30 PM
LiquidBlue's Avatar
Transmission: MD8
Thanks for the details. I'm a way off from installing, but good to know. just drug it out of the deep, dark recesses of my garage to see what it looked like, hadn't played with it in a while. was just starting to get my mind on it and ran across this.... hopefully be year end it will be in.
rwdtech
Feb 10, 2006 03:48 PM
ol'blue86
Sep 9, 2005 09:33 PM
Pablo
May 29, 2004 01:55 AM
87ROCZ
Mar 18, 2003 08:27 PM
87ROCZ
Jan 14, 2003 09:09 AM
