Found a Foreign Oblect In my Reaerend
Old Feb 1, 2020 | 04:00 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I know I just could not help myself when titling this post!
All seriousness, I was changing the diff fluid and when I got the cover off I found this washer looking thing. The reason I say "looking" is it is flexible, like a compressed fiber or maybe hard rubber. it is not steel. The lines are not ribs, just dark stains on both sides. Since it is not torn and the posi rear performs as it should I assume it did not just fall out and it was left in there by the PO that change out the diff.
Old Feb 1, 2020 | 04:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Found a Foreign Oblect In my Reaerend
Supposed to be in there, glued on the cover. It's a debris catcher magnet thingie
Old Feb 1, 2020 | 05:01 PM
vinny R's Avatar
Car: 1991 Z28
Crap, I did not put it back in. It was just laying in the bottom. Do you think it will be a problem if it is not in there?
Old Feb 1, 2020 | 05:37 PM
Drew's Avatar
But I thought it was just ICP'd to the cover like the magnet in the trans pan? It goes over the dimple in the cover.
Old Feb 1, 2020 | 05:47 PM
vinny R's Avatar
Car: 1991 Z28
The magnet is not very strong so maybe it just fell off. I do have a dimple in the cover and the cover is a aftermarket chrome. There was no metal stuck to it when I pulled it out, Do you Think I will be ok if it is not in?
Old Feb 1, 2020 | 05:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Probably not a big deal. But if it bothers you enough, remove the cover and stick it back onto the lower portion on the cover.
You can probably get away with a rare earth magnet or two, stuck on the outside of the cover, if you really don't want to dump all that fresh lube and additive.
Edit: Aftermarket cover, aluminum? If it bugs you not being in there, remove the cover and put it back. I'd epoxy it back in place.
Old Feb 1, 2020 | 06:00 PM
OrangeBird's Avatar
Car: 1989 Firebird
Nope , not OK , think nuclear explosions , biblical floods , the emergence of flying Alligators , that sort of thing !!!!
Kidding ! Just kidding ! Put it back on your next oil change (presuming you do regular differential oil changes) and you'll be fine .
And for the meantime I really like Paulo's external magnet idea ...
Old Feb 1, 2020 | 06:01 PM
vinny R's Avatar
Car: 1991 Z28
It is steel. Thanks and yeah I don't want to dup the Synthetic Mobil one as the car hasn't left my garage. I will put it aside and the next time I am under there I will put it back in.
Old Feb 1, 2020 | 06:40 PM
vinny R's Avatar
Car: 1991 Z28
And for the meantime I really like Paulo's external magnet idea ...[/QUOTE]
Me too! BTW we do have alligators here in FL, I will have to keep them away from my rearend!!
Old Feb 2, 2020 | 02:03 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'll bet you still laugh when somebody farts, don't you?
Old Feb 2, 2020 | 06:38 AM
vinny R's Avatar
Car: 1991 Z28
Guilty!
Old Feb 2, 2020 | 09:47 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I think the worst part of this thread is that you didn't even know that was in your rear end the whole time.
19CAMARO85
Feb 3, 2008 11:17 AM
scooterist50
May 8, 2007 03:05 AM
Cadillac
Apr 29, 2007 12:49 PM
TonyC
Jan 28, 2003 02:15 PM
tanager11
Oct 24, 2002 04:43 PM
