will this 700r4 fit behind my L98?
Old Feb 17, 2020 | 10:30 PM
L98———'s Avatar
Hi, I had a question I need to find the answer to. I saw a post on Craigslist for a recently rebuilt 700r4. It’s cheap, so I asked him for the numbers. I got 5MK192A, which was last behind a 55 Chevy with an LS swap. I can’t find what it was originally out of. He said he ran it in his 1987 el Camino. Any ideas if it would bolt onto my L98 without too much fabrication? I figure I may have to change the tail housing and servo at bare minimum. Thanks for any replies.
Old Feb 19, 2020 | 11:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: will this 700r4 fit behind my L98?
1985. Might be truck. And wiring connection should work for a third gen. Not the prom queen as far as 4L60/700R4 units go. But sometimes it's fun to see how much harder the ugly ones will try.
Old Feb 20, 2020 | 09:18 AM
L98———'s Avatar
Hey could you tell me how you were able to identify these numbers? Thanks
Old Feb 21, 2020 | 10:46 PM
jmd's Avatar
jmd
Alpha Number Number format is commonly used on the 700-R4 / 4L60 with the year indicated and the numbers referring to other aspects of the specifications.
Although pressure switches and solenoids were threaded into the valve body with different wiring arrangements in the pan to control torque converter lockup differently for different applications, the ECM to transmission wiring is compatible across a vast number of them, for the purpose of functionality. And virtually anything 85 should be plug and plan for the thiird gen TCC wiring connection.
Old Feb 22, 2020 | 05:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Where are you located at?
Might be able to help you out if near by.
Old Mar 1, 2020 | 02:12 PM
L98———'s Avatar
hi, I’m located in southern Vermont. Thanks
Old Mar 1, 2020 | 03:47 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Old Mar 1, 2020 | 03:55 PM
L98———'s Avatar
Thanks for that diagram, I don’t know why I didn’t just look it up. So based off the diagram it’s out of an 85 pickup and was built on 1/29/85 first shift. Not sure about how hard it would be to fit in my car though, as in direct replacement or a bunch of fab work needing to be done.
Old Mar 1, 2020 | 04:21 PM
Drew's Avatar
Is it free? Not sure why anyone would want a 700R4 from before they added the auxiliary valve body. Every year of production, GM was fixing problems. Therefore every year you got a slightly better product. Generally speaking higher end cars got the upgrades soonest. So not only do you have a transmission that you have to adapt to fit the application, but it's from a fairly early 700R4 application, and it's from a vehicle that would have gotten the updates the latest. Hard pass.
Old Mar 1, 2020 | 04:28 PM
L98———'s Avatar
Not free or even close to it, but was rebuilt. I can get it for $400 and it’d be something just to get me bye for the first few months of the season.
Old Mar 1, 2020 | 05:17 PM
John in RI's Avatar
You'll probably just need one of these: ( F-Body tail-shaft housing for torque arm mount )
Where are you located ??
Old Mar 2, 2020 | 07:15 PM
jmd's Avatar
jmd
A tailhousing and speedo gears isn't much "adapting." I mean, I've put third gen 700-R4s in other vehicles and swapped the tailhousing and speedo gears out, the inverse of OP. I wouldn't pass up on getting a vehicle going because of those 2 items.
For that matter, in the third and fourth gens, going to a crossmember with the torque arm attachment, rather than having it on the tailhousing is a wise move, negating the need for a tailhousing swap.
And while I like the '88-up div. valvebody, plenty of 83-87 vehicles rocked on for tens of thousands of miles.
Negotiate the price? Absolutely. Pass entirely, in a market where the good 'uns are 28+years old and thinned from the market, or causing a much higher acquisition cost?
The possible downsides are getting shift points and firmness that aren't as performance oriented, nor WOT 4th.
Old Mar 2, 2020 | 10:39 PM
Drew's Avatar
Having owned an 83, and a handful of 86s, I wouldn't want to take the time to put one of those transmissions behind a 350 TPI. Is it possible? Sure. Is it a compromise I'd be satisfied with? Not at all. I certainly wouldn't spend a few hundred dollars on something I'm not going to want a few months later. Not to go backwards. But then I'd rather walk or drive a beater while I save up to do the job right, then cut corners and have to do the job twice.
tom7340129
Apr 13, 2010 09:28 PM
FireBirdSoldier
Mar 9, 2009 04:28 PM
Drew
Feb 7, 2002 08:26 PM
