One large and 7 small checkballs
Old May 30, 2020 | 07:54 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
I was just putting together my valve body and I noticed in my parts bucket. There are 7 small check ***** and one larger checkball. I can’t remember when I tore it down. I know for sure when I rebuilt my pump there was a checkball in the pressure relief port with a stiff spring. Does gm do weird ithings like this. I know it’s not the usual .250
Old May 30, 2020 | 08:18 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Re: One large and 7 small checkballs
Maybe it’s my auxiliary valve body. I counted a total combined 7 that go into the valve body and case. I guess it’s called the #12 checkball
Old May 30, 2020 | 09:15 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I think it’s called a 5/16 checkball and they usually omit it
Old May 31, 2020 | 06:06 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Ok I think I figured it out check out this video from Hiram on YouTube
Old May 31, 2020 | 06:16 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I know I’m absolutely sure that the larger checkball is not from the pump. I kept everything separate, I recall that I had to push hard to get the spring in the pressure relief valve while I hammered in the retaining nail-like pin into the pump. It was obviously fighting against the ball
Old Jun 2, 2020 | 10:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Originally Posted by zupta82
Ok I think I figured it out check out this video from Hiram on YouTube https://youtu.be/zvVPIXzeEFc
You did catch that the 5/16" check ball goes in the case, yes?
In the ATSG manual, there's a leak check for the captured 3rd Accumulator check ball (#7). If you're already down the road, it'd just forget about it.
-=Z28=-
Sep 24, 2019 04:25 PM
GeneralDisorder
Apr 22, 2019 10:44 AM
gad
Aug 21, 2011 09:57 PM
Goonv8
European Region
Aug 20, 2008 02:16 PM
daves12secV6
Jul 11, 2007 08:49 PM
