700R4 spraying fluid
Old Jun 10, 2020 | 07:22 AM
NotoriousREV's Avatar
At the weekend, just cruising about at about 50mph there was suddenly loads of smoke out of the back end. I slowed to a stop, thinking it was an engine problem but it was running fine but when I set off again I had almost no drive at all. When I got out and checked, the tranny was pumping fluid out of the front of the fluid pan with the engine running.
The pan isn’t loose, so I assume the gasket has blown in spectacular fashion and very suddenly as it wasn’t leaking any fluid at all previously.
Is it likely to be anything other than just the gasket blowing or do you think I’ll get lucky?
Old Jun 10, 2020 | 01:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 700R4 spraying fluid
The fluid is probably coming from the pump seal.
Old Jun 10, 2020 | 01:56 PM
Wouldn’t that spray fluid from the bellhousing rather than from the pan?
Old Jun 10, 2020 | 03:04 PM
GeneralDisorder's Avatar
It would run down and look like it's coming from the pan most likely. I agree it's probably the pump seal.
GD
Old Jun 10, 2020 | 03:23 PM
GD
It’s 100% spraying from the front lip of the pan in 2 jets from near the 2 outermost bolts when the engine is running.
Old Jun 10, 2020 | 04:43 PM
Well I would suggest a new pan gasket then. Never seen such a failure. Must be a really cheap gasket or something.
GD
Old Jun 10, 2020 | 04:56 PM
GD
Yeah, I’m half expecting it to be just sealant or something. I’m in the UK so waiting a week while my gasket is shipped across the Atlantic.
FireDemonSiC
May 16, 2012 10:38 AM
srgould41
Jan 9, 2011 02:32 PM
80schild
Jul 3, 2008 08:08 PM
SHAGME
Apr 14, 2003 07:34 PM
