T5 noise, neutral only...
Old Sep 28, 2018 | 09:45 PM
Roblaza's Avatar
Hey guys, I'm getting a new noise from the t5 in my 89 rs.
It is a whine type noise that only occurs when cold and in neutral sitting still, foot off the clutch pedal. If I put some slight pressure on the shifter where 4th would be it stops the noise all together. If I depress the clutch pedal it stops the noise all together. It has fresh fluid in it, new clutch kit with new centerforce release bearing and pilot. No visible leaks anywhere.
I've searched and found whine noise threads but they don't seem to apply to my specific situation on only being noisy while stopped in neutral.
Any t5 gurus in here that can offer some insight?
Old Sep 28, 2018 | 10:16 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: T5 noise, neutral only...
Sounds like the throw out bearing.
Old Sep 29, 2018 | 01:19 AM
Drew's Avatar
The throw out bearing shouldn't really even be touching the pressure plate with the clutch out. If the trans makes noise when the the clutch pedal is out, shifter in neutral, than the input shaft is locked to the crank with none of the gears engaged. So the noise is coming from the transmission until you press the clutch or preload the trans by applying pressure to the shifter. I'm gonna go with noisy bearings in the trans.
Old Sep 29, 2018 | 07:32 AM
Not the throwout bearing.
THIMK: the throwout bearing is the piece that the clutch linkage presses on, and in turn presses on the clutch. It might make noise when the clutch is being pressed, or when it's not; but has NOTHING WHATSOEVER to do with "neutral".
It's just the innards of the transmission spinning. In neutral with the clutch out, the clutch disc is forcing the clutch gear to spin, which forces the countergear to spin, which forces every one of the gears to spin on the mainshaft. The mainshaft, which is connected to the drive shaft, is sitting still if the car is, or spinning at some rate related to the car's ground speed.
A certain amount of noise in that operating state is normal. If it's not inordinately noisy any other time, it's fine.
Old Sep 29, 2018 | 01:58 PM
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
I'm just finishing rebuilding my T5, I would guess it's the bearings between the input shaft and the output shaft. When I pulled my trans, it only had 1 of 4 bolts so it was being held up by the shaft so the ends were completely destroyed, I noticed this same kind of whine in natural and not in gear before I pulled it.
Old Sep 29, 2018 | 04:47 PM
Yup, could be that. The clutch gear (its name isn't "input shaft") and the mainshaft (not "output shaft") have a difference in their speeds of engine RPM when in neutral, clutch out, and sitting still.
Could also be the countergear bearings. They often do the same thing when they've been run dry. And that part of course is also spinning at any time that the clutch gear is.
Old Sep 29, 2018 | 06:03 PM
Car: 1986 Camaro
Engine: 2.8
Lol, that what I was able to find my new ones called when I replaced them and what the diagrams from tremec called them, so I was just using those terms. I learn something new every day.
Old Sep 29, 2018 | 06:21 PM
Tremec... a foreigner, and a newcomer.
Old Sep 29, 2018 | 06:38 PM
Roblaza's Avatar
Well, it seems to come and go. Some mornings it makes the noise, others it doesn't. I know the trans has never been run dry, and this is a new noise that I've never noticed in the previous 2 years of owning the car.
Just seems odd that it has started out of the blue like this.
Old Nov 4, 2019 | 02:18 PM
okay's Avatar
Car: 91 Firebird
Engine: 5.0L
Transmission: WC 5 speed manual
Mine just started acting the same way this morning, too. 125k miles.
Old Jun 10, 2020 | 06:28 PM
okay's Avatar
Car: 91 Firebird
Engine: 5.0L
How's your T5 now? Same noise? Fixed?
S10Wildside
Sep 27, 2010 04:28 PM
devianb
Jan 7, 2003 03:20 PM
z28onTweenkies
Jan 31, 2002 11:08 PM
JETHROIROC
Sep 12, 2001 01:03 AM
