Engine or transmission knock. I already replaced trans mount.
Old Jun 21, 2020 | 08:10 PM
Harrisbueler's Avatar
Im extremely down, i got the car running after sitting for 4 years and got it driving and then it started knocking. Definitely not coming from the engine bay. I put it on blocks and spun the tires from 1st to 5th. The sound got progressively worse. Whats strange is if i shift it smooth and nice it doesnt seem to make the noise. I put my hand on the bell housing and it seems to be coming from there but I'm not sure. My friend said it might be play in the crank shaft. I really can't tell and i can't find a thread where someone experienced this. Please help! I'll post a video.
https://youtu.be/DH5Hiu5siGE
Old Jun 21, 2020 | 09:51 PM
GeneralDisorder's Avatar
Re: Engine or transmission knock. I already replaced trans mount.
Definitely sounds like a problem inside the trans. Pull the trans and check out the clutch and throw out bearing, etc. Might need a clutch kit or perhaps a trans rebuild. These are really easy transmissions to remove. Just pull it and see what your dealing with.
Make sure that's not a u-joint failing in the driveline first.
GD
Djk96
Oct 26, 2016 02:49 PM
Buggy Disaster
Apr 23, 2012 03:08 PM
Jstuck3y
Dec 16, 2008 12:03 AM
Gunny Highway
Jun 30, 2002 03:12 PM
