speedometer gear selection
Old Sep 11, 2020 | 04:36 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
1992 RS, 305 TBI, Auto originally 2.73 rear.
Swapped to a 3.73, Running Iroc 16s. Can someone tell me which driven and drive gears I need to correct the speedometer? Also, I installed a rear end from what I was told was a 2002 trans am, and I used a Richmond overhaul kit when I rebuilt the rear. The front pinion seal is puking. Did they change pinion or yoke diameter throughout the years? It's leaking between the seal and the outside of the yoke.
Thanks in advance!
Old Sep 11, 2020 | 11:48 PM
vorteciroc's Avatar
Top Answer: 1
Re: speedometer gear selection
What size are the rear tires?
Example: P245/ 50ZR16 = 245-50-16 = 245mm width, 50% sidewall aspect ratio, 16" diameter wheel.
Post your tire size in the equivalent form of: 245-50-16
The tire height is part of the equation, with the ring and pinion ratio for the speedometer gears.
Old Sep 12, 2020 | 12:52 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
You need a 15 tooth drive gear (gray) and a 43 tooth driven gear (purple) for a 3.73 rear gear ratio with 26-inch tires.
A 245/50-16 is 25.6 inches, so a 44 tooth (dark gray) driven gear is what you'd need...
Old Sep 13, 2020 | 03:14 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I'n interested in this also, what does everyone use to figure out what color and tooth count you need
Old Sep 14, 2020 | 06:20 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
For the 4L60, 15/44.is what is available.
Old Sep 17, 2020 | 04:01 PM
draco's Avatar
Engine: 5.0l TBI
I am running the 245 - 50 - 16 so that is a 25.6 inch tire. I still have the 700r4 trans. Originally the car had 2.73 rear and the stock 15in color matched wheels. Can anyone tell me if either the drive or driven gear will be reusable and if I will have to change the housing for the driven gear? I read this note on TCIs website:
"Two 2.078" diameter housings, each made from either aluminum or plastic, are available for driven gears with 34 or more teeth. One fits gears from 34 - 39 teeth and the second one fits gears from 40 - 45 teeth."
Thanks again fellas
Old Sep 17, 2020 | 09:33 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
My 90 Formula originally came with 2.73 rear gear. I had a red, 17-tooth drive gear from the factory. I swapped out to a 3.42 gear and was able to swap out the original driven gear for a 45-tooth, but first had to switch to the other VSS, as you mention. You might read up on the sticky: https://www.thirdgen.org/forums/tran...eedometer.html
Old Sep 20, 2020 | 12:42 PM
jmd's Avatar
jmd
Thanks again fellas
Jack the car up, remove the 10mm headed M6 bolt, use a mirror to check drive gear color and count driven gear teeth. Going by color isn't a reliable way to count teeth. But it's very likely a 2.73 car still has a red 17 tooth drive gear.
If the car functioned correctly before gear change:
buy a 44t driven gear, 15t drive gear, and if it was a 34-39t driven gear, buy a correct 40-45 VSS..
GermanV8
Nov 10, 2017 12:53 PM
leek157
Oct 16, 2008 11:45 PM
1991Formula350
Sep 12, 2007 10:06 AM
gtechfan01
Feb 11, 2005 12:29 AM
RED92BIRD305
Mar 25, 2004 03:03 PM
