9 bolt differential oil and fill plug
Old Oct 30, 2020 | 05:43 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I have a borg warner 9 bolt with 45,000 miles. I changed all the seals since one was leaking a bit. now I need to add new oil. and would like to change it to synthetic. what is the best oil and additive combo for my 9 bolt?
the other issue I have is that the filler plug is a bit craked. is there a place where they sell them or should I just add a bit of silicone to the plug?
Old Oct 30, 2020 | 05:47 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: 9 bolt differential oil and fill plug
I have the Borg Warner rear in mine and I went with Royal Purple 75W90 and have had no issues. I did not have to add the friction modifier either with that one. For the plug you should be able to find one at any auto parts store I believe.
Old Oct 31, 2020 | 11:44 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I used the same Royal Purple oil as Red Dragon and as for the plug, the part number is 10033568, so you should be able to just Google it and choose the one that fits your budget best.
Old Oct 31, 2020 | 12:01 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
There was a recent thread here about the filler plug, you might search a bit for it
I used Amsoil 80-90, though at this point it may not make much of a difference what you use now depending on the mileage, the cones might be bottomed out.
Also, the service manual says not to use friction modifier unless the rear chatters, just an FYI
Old Oct 31, 2020 | 04:30 PM
GeneralDisorder's Avatar
TA rear cover fixes the plug issue and gives you a drain plug.
And yeah the cone type posi is straight hot garbage. Do yourself a favor and put a Torsen in it while it's out.
GD
Old Dec 20, 2020 | 12:28 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Something to consider
modified 9 bolt diff. cover
bensbaby
Nov 4, 2019 06:25 PM
DJP87Z28
Sep 14, 2011 06:16 PM
novafirebirdguy
Feb 14, 2011 12:09 PM
squirrelybird
Dec 9, 2002 09:24 PM
92 Red Firebird
Aftermarket Product Review
Oct 18, 2002 07:25 PM
