4th gen alum. driveshaft swap
Old Nov 13, 2020 | 05:43 PM
StunMan's Avatar
Car: '91 RS vert
Engine: mild TBI 305
Axle/Gears: 3.43 pos
In an effort to lose weight ( and rotating weight at that ) have acquired a low mileage 4th gen alum driveshaft. It is a perfect fit and works well. The one thing that was different is a harmonic balancer type of thing on the front yoke of the 4th gen shaft. The yokes appear to be the exact same size, shape, and form. In fact you can kinda see where this thing could be pressed onto the old yoke.
With the goal originally to be weight loss, and the old shaft did not have one. Can I remove this part? it would easily save another couple pounds. This is a track day car only. Could care less about damping harmonics out of the chassis, or long term wear.
Old Nov 13, 2020 | 06:10 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 4th gen alum. driveshaft swap
Do you have a picture? Im aware of the balancing weights but not a dampener.
Old Nov 13, 2020 | 07:25 PM
StunMan's Avatar
Car: '91 RS vert
hope this works with google photo
https://photos.google.com/album/AF1Q..._yTSkS1zWtVRZC
getting it ready for some paint
Old Nov 15, 2020 | 09:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
My understanding of the purpose of the front damper was to reduce noise.
RBob.
seanof30306
Jun 16, 2016 05:15 PM
gmoutdoorsman
Jan 1, 2015 08:38 PM
gbctp
Oct 1, 2013 06:44 AM
klumb15
May 1, 2013 10:35 AM
grove
Oct 12, 2007 06:28 PM
