700r4 acting weird
700r4 acting weird
I have a 89 camaro rs that used to be a v6 but was swapped to a 350 with an auto 700r4. So I finally drove the car for the first time after it’s been sitting about 7 years. I changed all the fluids including the trans fluid. So the car goes into reverse no problem backs up like a normal car, I put it in drive it moved and shifted into 2nd no problem, well then it shifts into third and it felt like neutral. If I give it about half throttle or wot it will grab gear and go just fine. But if I’m not accelerating decently hard it doesn’t move. Is this a torque converter problem possibly?
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: 700r4 acting weird
Fluid exchange = exchange old fluid for new
Probably not a TV cable problem.
Not a converter problem. Converter does the same things no matter what gear it's in.
More likely, the 3-4 clutches are toast.
I doubt the fluid thing will do anything, especially since you say you've already done it, but you never know... might enable it to drive one more day or something. But once clutches start to slip, it's usually pretty much all over with for them.
Car: 1985 Z28
Engine: 305 LG4
Since it engages when you rev the throttle it is less likely to be clutches going bad. Those generally slip worse the more throttle you give it. Sounds like something sticking and not clutch packs going out.
Thanks everybody I’m not willing to accept it’s the clutches yet because it’s the opposite of a slipping clutch but I do believe something is stuck and it would make sense on a car that has been sitting for almost a decade and drove fine prior.
