Some 9bolt info please?
Old Feb 19, 2021 | 01:27 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello, im trying to buy a 9 bolt housing from http://tacreationsusa.com/ but they want me to tear open my rear end to count the number of roller on the inner pinion bearing.
Apparently there were two different types of housings used, one being a bit more rare than the other. I can't take apart my rear right now, but I doubt I have the lesser used model, and I cant really find any other information about it.
They say its not year or gear ratio dependent, so the only way to find out is to open it. I cant do that at the moment, and will be time crunched to swap out the rear as it is. So I need this thing asap.
I wanted to see how many people actually had this "rare" model and if someone could give me the common roller count.
Would be much appreciated!
Old Feb 19, 2021 | 02:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Some 9bolt info please?
As far as I know there is only one bearing size for the 9 bolt for the inner pinion bearing. I think they are blowing smoke up your a ss or they don't know what they are talking about.
Old Feb 19, 2021 | 02:08 PM
Annihilate's Avatar
Engine: 5.0
Kinda what I thought.
Also, would you suggest replacing this bearing while doing a carrier swap?
Or any other parts I should replace while doing a transplant of the gears to the new housing?
Old Feb 19, 2021 | 02:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Unless you get known mileage, I would replace all the seals at the very least. That requires new axle bearings and a crush sleeve for the three seals. Replacing the other bearings isn't a bad idea, but you can inspect them and see whether they require changing before throwing money at it.
Personally I would change all the bearings and seals so you know they are new instead of unknown. It's not a lot of money, but it takes time to change them, or more money if you just have someone else change them
Old Feb 19, 2021 | 02:47 PM
I'm pretty sure there is in fact more than one head bearing for those, but I also think it's an early/late kind of thing, and these cars are all early. GTOs and such are late. I could easily be wrong though.
Not sure what difference the housing you have now, matters in terms of the housing you want to buy; but what do I know.
Axle seals are a major issue with parts sourcing for those. There's any number of posts on here about one being N/A, another doesn't fit right, etc. etc. etc.
If it was mine I'd change every bearing and seal in it. Can't imagine how it would be a good idea to put used ANYTHING, least of all bearings, into a different housing, anyway; that makes no sense at all to even consider. Besides, there's no telling when all of those things are going to just disappear from the face of the Earth forever, and it would SUCK to have some one of those things to fail later on, and it no longer be available.
Old Feb 19, 2021 | 03:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The Timken catalog doesn't show any alternates for the year range for 3rd gen 7.75"
Old Feb 19, 2021 | 03:10 PM
Annihilate's Avatar
Engine: 5.0
Does this look like everything I need?
I already had a 9 bolt 3.45, but I was in a minor accident that bent the housing. So I was looking for a straight replacement.
I've got a new Torsen carrier im going to have installed as well, so not sure what all is included with that... This is a new world to me.
Old Feb 19, 2021 | 04:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The two black axle seals are wrong, but that is what Timken says fits. They WILL work, but they aren't the correct seal. There is already another post for 9 bolt info. search for my name and you'll find the Yukon part numbers for the correct seal, along with the SKF numbers
Old Feb 19, 2021 | 06:28 PM
Annihilate's Avatar
Engine: 5.0
It seems the numbers for the seals that are proper fits are YMSG1001 and 1002
SO Let me put together a little part list to make sure I have everything for this swap...
Already have the carrier.
Axle Seals - Summit Racing - YMSG1001 and 1002 - $84
Pinion Bearing - ??
Pinion Seal - http://www.ratechmfg.com/pop_up_order%206120.htm - $4
Carrier Bearings - http://www.ratechmfg.com/pop_up_order%209024.htm - $35
Wheel Bearing - http://www.ratechmfg.com/pop_up_order%209107.htm - $32x2 - $64
Pinion Shim Pack - http://www.ratechmfg.com/pop_up_order%201104.htm - $8
Carrier Shim Pack - http://www.ratechmfg.com/pop_up_order%201145.htm - $20
Smart Sleeve - http://www.ratechmfg.com/pop_up_order%2011004.htm - $13
Pinion Nut - http://www.ratechmfg.com/pop_up_order%201508.htm - $9
Ring Gear Bolts - http://www.ratechmfg.com/pop_up_order%201303.htm - $20
Cover Gasket - http://www.ratechmfg.com/pop_up_order%205124.htm - $4
Alternatively there is this kit - http://www.ratechmfg.com/pop_up_order%20332K.htm - $131
I see that kit has a Bearing Race - LM102911 but I am not sure which pinion bearings from that kit I would need.
And this kit https://www.hawksmotorsports.com/com...tallation-kit/ - $149 Seems like this has everything except my wheel bearings and axle seals
Is anything missing from the kit?? Thanks in advance!
Total - $261
Am I missing anything? Anything I don't need?
Old Feb 19, 2021 | 06:49 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I wouldn't buy all that from Ratech, but that's just me. I prefer to know what brand I am getting instead of brand X with the proper part number.
You could also get the TA performance girdle
Old Feb 19, 2021 | 06:58 PM
Annihilate's Avatar
Engine: 5.0
The girdle can be replaced at any time, I don't really have infinite funds here lol.
How do you feel about the hawks pack? Also open to alternative wheel bearings, though I thought Koyo was decent?
Old Feb 19, 2021 | 07:05 PM
I've been to Ratech's factory, in the Cincinnati area, and poked around their shelves more than once with their (female) manager to find what I needed ATM. BTW she was TOUGH: kind of a biker chick, but not in any kind of a bad way; more like, her kids were gonna grow up to be football players. I was quite pleased. I would not hesitate, in the sense of "prefer to know what I'm getting", to do business with them, as I wandered around among their punch presses and whatnot.
Bearings are a different story. Used to work at a place that was a distributor of them for electric motors. BIG electric motors. We tended to prefer the Japanese brands at that time; SKF, NTN, those brands. Of course this was MANY decades ago. The reason of course was, Japanese, German, Polish, Korean, British, even Russian, factories were bombed to SHRAPNEL between 1940 and 1955; many former industrial powerhouses were OBLITERATED; but American factories weren't. As time when on, all those other places got nice shiny brand-new plants built with the latest technology. Here, nothing had to be renewed. We rested on our laurels for DECADES. So we saw stuff like the tires from US factories that were A TOTAL JOKE next to Michelin (French) or Bridgestone (Japanese) products... anybody here old enough to remember the Firestone 500 scandal? Bearings were one of those things that were strategically annihilated during those wars, so all those other place have NEW factories, where WE DON'T. Go do some travel outside the US, you'll see EXACTLY what I mean. Lose the "we're the best" snobbishness and realize that EVERYBODY on the planet is equally smart and we that ALWAYS have to be on our best game in more than just speeches and bombast, or they're gonna out-compete us if we don't BUST OUR *** instead of the complacent "oh we're American we deserve to have all this".
Old Feb 19, 2021 | 07:07 PM
Annihilate's Avatar
Engine: 5.0
I certainly have no qualms about getting parts made elsewhere, my main focus is quality. I don't want to touch this thing again (rear) for a long while, so I just want to make sure i'm covered.
Old Feb 19, 2021 | 07:10 PM
Being in Michigan, you could easily enough drive down to Ratech yourself and see what there is to see. Talk to the people there, look around, decide if that's the way you want to go.
Old Feb 19, 2021 | 07:13 PM
Annihilate's Avatar
Engine: 5.0
Perhaps one day, but I am on a time crunch to get this done as soon as possible.
Ratech would be fine for me, just want to make sure I have a comprehensive list, or if their "complete sets" are truly complete for what im doing.
Old Feb 20, 2021 | 04:13 PM
GeneralDisorder's Avatar
My 86 has the (apparently more rare) small pinion bearing. Found this out after getting it apart.
It could be, rather than an early/late thing, a casting/machining manufacturing decision. Idk and it's pure speculation, but sometimes you find that a casting will not accommodate machining to a specific dimension due to shifting or shrinkage encountered in the casting process.
GD
Old Feb 20, 2021 | 04:37 PM
Annihilate's Avatar
Engine: 5.0
How much would I realistically have to disassemble to get to this bearing? I'd like to get the housing this week, but I'd guess the headache would be bigger if the housing didn't accommodate my gears.
Old Feb 20, 2021 | 04:46 PM
Complete disassembly and setup.
Why does it matter? Just get both bearings so you have both on hand.
There is no difference in the gears themselves.
GD
Old Feb 20, 2021 | 05:03 PM
Annihilate's Avatar
Engine: 5.0
According to the guy I'm trying to buy the housing form, there is a different housing for the smaller bearing?
Old Feb 20, 2021 | 05:28 PM
Of course the housing is different - so buy both bearings and have them both on hand for when you assemble it.
I'm not seeing the issue here. Why would you re-use the bearings from a different housing anyway?
I got all my parts front Ratech. No issues and I'm 400 HP at the crank and I ABUSE that junk.
GD
Old Feb 20, 2021 | 08:05 PM
soupman's Avatar
I also have 1986, and it had the smaller bearing like GD’s. Not sure if it a year thing for the switch.
Old Feb 20, 2021 | 10:01 PM
Annihilate's Avatar
Engine: 5.0
I think we're missing the point here lol.
I already have a 9 bolt in my car.
I will be reusing the gears, however replacing the carrier.
I will be replacing the bearing, yes, but since there are two different housings, wouldn't the gears be different in each?
So theoretically, if I got the wrong housing, my gears wouldn't fit, is this accurate? Or are the gears essentially universal?
Jeff from TACreations said it happened on an 89 as well, same year, same gears, different bearing.
Old Feb 20, 2021 | 11:37 PM
No the gears are the same regardless. You just need both bearings on hand.
GD
Old Feb 21, 2021 | 12:03 AM
Annihilate's Avatar
Engine: 5.0
Gotcha, easy.
Thank you!
9sinthe86TA
Nov 30, 2020 03:31 PM
jtwoods4
Aug 16, 2014 08:18 PM
kill4thril
Aug 3, 2011 07:22 PM
87IROCZ350TPI
Jun 7, 2006 09:26 PM
HenryC
May 31, 2002 06:23 AM
