PerformaBuilt Transmissions
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Anyone here use PerformaBuilt Transmissions? I had my 700r4 built by a local place and 3-4 gear failed twice with less than 100 miles.
Re: PerformaBuilt Transmissions
Car: 1990 IROC-Z
Thanks for the response, Pro-Built Automatics is the first place I tried and have called and texted multiple times, no response. Are they still in business?
My experience with Performabuilt is about 5 years ago before we swapped to a manual. They built a 700 for me on a 12 month "throw what you want at it power wise, if it breaks we'll repair it" warranty. It held to 800 hp with zero issues on a Procharged SBC. If I were still running automatics, I would use them again.
Car: 1990 IROC-Z
@Beater79TA Thanks for the feedback I plan to discuss with them as I have a supercharged SBC also
Car: 1990 IROC-Z
@punkmaster98 when it broke after the first rebuild I assumed that was the issue but after the second fix I had a mechanic check the adjustment before driving and it was set up correctly but still failed. I would like someone to check it out as I assume it was not built correctly.
When he is full on Jobs to complete; you can most likely only leave him (Dana) a message.
However he does return the messages when he has an opening to take on another Job.
It is well worth the wait, if he is full on Jobs currently.
But like I said... Performabuilt is also great!
Car: 1990 IROC-Z
@vorteciroc thanks for the info, I got a hold of him and plan to take the 700r4 to him for a rebuild
dvmeter
Jan 7, 2010 08:30 PM
skiroulertx447
Mar 29, 2009 08:13 PM
