84 Z28 what Tranny
Old Jul 26, 2021 | 11:11 AM
cjpenny89's Avatar
84 Z28 what Tranny
I have a 1984 Z28 with an automatic with overdrive. Can someone tell me what Tranny is in this car or what I need to do to look up the correct tranny? I was told it was stock from the previous owner who said it was a 200r4 but is it a TH200 or something instead?
Just looking for the correct terminology on this.
The car already has an crate engine in it 350 but the edelbrok 1406 is coming off and we are installing a Holley Sniper EFI and I think I need to get a TCC lock up switch kit for it?
Can someone tell me if the TCC lock up could still be working even without most of the original ECU hooked up? It appears that the TCC wires and vacuum are all still hooked up. I want to remove the ECU and wiring but is it still controlling the TCC lock up switch?
I know the correct thing to do is probably remove it all and buy a kit for the TCC. I am just interested in if you think it is still working now.
I am also interested in MPG once I get this all done currently it only gets 8 to 10 MPG. I thought it would do better then that but maybe it isn't getting into OD?
Chad
Old Jul 26, 2021 | 12:49 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: 84 Z28 what Tranny
It's a 700R-4...
Old Jul 26, 2021 | 04:14 PM
The Holley may have accommodation for TCC. Might want to look into that further.
Old Jul 27, 2021 | 07:05 AM
cjpenny89's Avatar
Thank you so much for the info I looked into the Holley EFI and yes it sure does sound like it can control the TCC lock-up. I will just have to do some leg work but it saves me some extra money and I will take out all the ECU wiring and contact Holley on what I need to do.
Thanks for pointing me in the right direction!
Old Aug 11, 2021 | 01:43 PM
cjpenny89's Avatar
The Holley Sniper doesn't have the option as of right now. I did confirm that it is a square pan and is the 700R4. I bought the lock up kit from TCI
bears41666
Nov 2, 2012 11:48 PM
RMK
Mar 18, 2004 05:24 PM
rsc350
Jan 13, 2004 05:20 PM
foney_email
Aug 9, 2002 10:47 AM
FatOne
Jun 7, 2002 02:56 PM
