Adjust the TV cable for 700-4r
Old Nov 20, 2021 | 01:45 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Here is a link from youtube as to how to adjust the tv cable for a 700-4r tranny. Is that the correct method? My car is a 1984 Trans AM with the 700 tranny all original.
Old Nov 20, 2021 | 02:10 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Adjust the TV cable for 700-4r
Not exactly. You do the adjustment with everything connected. IIRC, you first hold the button in and shove the end back towards the firewall so that it is all the way inside the housing as far as it will go. Release the button and rotate the throttle arm to full throttle. The TV cable adjuster will click as it follows the throttle arm pulling the cable to full throttle. And that's it, it is adjusted and you are done.
Old Nov 20, 2021 | 03:46 PM
vorteciroc's Avatar
Top Answer: 1
That will work as long as the Throttle-Body/ Carburetor Linkage geometry is correct.
Small additional adjustments, of a Click or Two in either direction, can be helpful at times.
jjskibbs
Jun 7, 2008 04:31 PM
rv1890
Mar 22, 2007 06:43 PM
bonz
Jul 22, 2005 01:41 PM
Joehrdcor
Apr 21, 2005 11:12 PM
Randy82WS7
Oct 10, 2003 02:49 PM
