Adjusted the TV cable, Now Tranny Shifts Hard
Old Apr 15, 2005 | 10:51 AM
Joehrdcor's Avatar
Car: 89 Firebird Formula
Engine: 305 TBI
I just adjusted my TV cable by the process explained in the Tech Archives. I held the Tab in and moved the cable housing towards the front of the car till it stopped. I then opened the throttle fully, yet the tv cable did not ratchet into place. I drove the car, and it shifted harder than ever. I barely had to touch the pedal and it took off. Is this how it should function normally, or is my unit defective because it remained fully extended Please let me know, I have to be to work in a couple hours and I don't want a problem on the way there.
Old Apr 15, 2005 | 12:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it didn't ratchet forward at all, your cable may be stretched. It sounds like it's working better now than it was, though.
Old Apr 15, 2005 | 12:53 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I think you got it backwards.....
You want to get the little plastic center part that comes through the connector to be all the way back inside the part that connects to the bracket. That way when you push the throttle wide open it ratchets some of that center plastic part out towards the fromt of the car so that some of it shows....
Old Apr 15, 2005 | 01:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oops, I didn't read that as closely as vernw did.
Old Apr 15, 2005 | 01:33 PM
Joehrdcor's Avatar
Engine: 305 TBI
I followed the procedure as described in the haynes manual. With the nub fully extended foreward(towards the front of the car, I was unable to downshift to my lower gears at WOT. At the original location it seemed to bobble back and forth between gears. After playing around with it for a while, I decided to advance the nub foreward acouple clicks from the originol position. It seems to run the best there. If the self calibrating mechanism fails, should I adjust by feel, or should I put it back to where it origionaly was?
Old Apr 15, 2005 | 01:52 PM
HawaiianRS's Avatar
Car: 1989 RS
Engine: 5.0
I'm pretty sure you need to adjust it towards the mounting tab which is would mean pushing it back towards the firewall. I pushed the metal tab in and compressed the nub, opened the throttle, got a click and it shifts great.
I followed the instuction on this site
HERE
Old Apr 15, 2005 | 02:38 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
HERE
that's how i did it..
Old Apr 15, 2005 | 02:42 PM
Joehrdcor's Avatar
Engine: 305 TBI
Thanks to all. My unit must be getting stuck, I'll figure it out.
Old Apr 15, 2005 | 02:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Put it to where it self-adjusts to, and leave it alone. If it won't adjust properly, replace the cable.
Old Apr 15, 2005 | 02:56 PM
vernw's Avatar
Not sure there is anything wrong with yours, you just adjusted it out all the way where you went the wrong direction with the adjuster. Take it back in all the way so the throttle can pull it out to where it needs to be.....
Old Apr 21, 2005 | 03:46 PM
vortecbird's Avatar
Car: 91 Firebird
Engine: 350 Vortec TBI
Axle/Gears: 2.73 single tire fire
cable replacement
can the TV cable be replaced without removing the trans pan ?
my ratchet doesnt work well and i want a new cable.
Old Apr 21, 2005 | 11:12 PM
Joehrdcor's Avatar
Engine: 305 TBI
I don't know the technicalities of the TV Cable, but I was able to optemize my shifts by trial and error. My cable doesn't ratchet itself , so I played with it till it shifted better. Whether my cables worn out, I don't know, but I believe that manuel adjusting may be all you need. Mark the notch with some white out then progressively move the cable notch by notch.(The further the nub is extended towards the front of the car, the more likely the tranny won't downshift with WOT. The closer the nub is to the cable housing, the more likely the tranny will shift at lower RpMs. Unless you definately know that your cable is worn by fraying, the trial and error method should work out fine, or at least it did for me. Good Luck
suzuki949
Aug 28, 2015 08:07 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
