Eaton TrueTrac Oil, What are you guys running?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I am going to be getting a TrueTrac in my Camaro, What oil do you guys recommend? I run Amsoil 75-90 now and have plenty on the shelf, I am getting mixed answer when searching.
I run Torco RGO 85-140 In my Ram truck that has a TrueTrac in it.
Should I run the Torco 80-90 In the Camaro?
Torco 80-90?
Lucas 80-90
Amsoil75-90?
Redline 75-90 NS ( Synthetic with out friction Modifier)
( This is for my 2014 2 SS Camaro )
Torco 80-90?
Lucas 80-90
Amsoil75-90?
Re: Eaton TrueTrac Oil, What are you guys running?
Per Eaton's website
- A quality, petroleum-mineral based, GL5 rated 80w-90 gear oil should be used.
- Synthetic oils are not recommended for Truetrac applications. While some customers have found that synthetic oils works well in this application, Eaton has not confirmed under test conditions that all synthetic oils are compatible with Detroit Truetrac applications.
- Friction modifiers should not be used because they will decrease performance (reduce differential bias).
BLACK Z (12-17-2021)
Car: 86 Z28
I am leaning Towards Torco 80-90 RGO.
hydrolic144
12-18-2010 11:53 AM
