Judge this gear pattern.
Old Sep 23, 2022 | 06:54 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
I installed some 3.73 5-cut gears, and I want a judgement on these patterns.
This is with .006" backlash.
Old Sep 23, 2022 | 08:14 PM
NoEmissions84TA's Avatar
Re: Judge this gear pattern.
I think we are looking at PERFECTION.
Now I have to find the charts to make sure.
Old Sep 23, 2022 | 08:25 PM
Put the cover on, fill it with gear oil, and go do this.
Old Sep 24, 2022 | 04:15 AM
Drew's Avatar
Isn't that a gov-lock?
Old Sep 24, 2022 | 09:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This is where you should focus your hate or displeasure (gov-loc) instead of Gatorbacks and 1LE parts
Bahahahahaha
Old Sep 24, 2022 | 02:12 PM
Engine: TBI 305
Yup, sure is.
Old Sep 25, 2022 | 03:38 PM
Camaro71's Avatar
Well, then you're WRONG.
This is a (slightly) deep pattern. I would pull 0.003 and recheck.
Old Sep 25, 2022 | 08:33 PM
DIGGLER's Avatar
thats what i was thinking. i would do this and look again. maybe even pull more than that, like .005-10. if it winds up looking a bit shallow, you can get a rough idea of where perfect is. (in the middle of the 2 shim setups) now, once you know that, if you had to choose between a smidge too deep or a smidge too shallow, i would lean towards the smidge too deep. because there will be a small amount of deflection in the case/bearings/pinion/ etc while under load pushing the gears away from one another.
Old Sep 25, 2022 | 11:04 PM
Camaro71's Avatar
Wanted to type the same about overshooting to the shallow side, but because it's very close I wanted to save him the extra work.
If I can't get a perfect pattern, then I'm also leaning towards slightly deep and toe biased pattern.
Old Sep 26, 2022 | 06:35 PM
Engine: TBI 305
Thanks for the input! The original pinion shim was .035", and that yielded a pattern that was too high on the tooth.
Here it is, with .005" backlash:
This is the final pattern that I made last night. It's already installed and I drove it to work today; seems fine, doesn't make any noise. I'm not going to f*ck with it unless someone gives me incontrovertible evidence that it's going to explode in action.
This is with the .039" pinion shim, and .008" backlash (I sanded down an old solid shim for the final installation instead of a shim pack; I don't like using shim-packs on the driver's side of the differential. Or at all, if I can avoid it. ).
Chevy86 IROC-Z
May 11, 2022 02:51 AM
92RSv6
Aug 11, 2021 11:32 AM
89fast5oh
May 24, 2017 08:38 PM
RAPIDFIRE
Oct 17, 2007 02:16 AM
compuwiz1937
Feb 11, 2007 01:38 PM
