Clutch master cylinder support
Old Sep 25, 2022 | 09:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Does anyone have a diagram of the clutch master cylinder support I need to make one for the new car that I'm swapping a manual into. I can definitely look at my old car but not for a while but I'd like to get it made ahead of time.
Old Sep 26, 2022 | 04:15 AM
onebdgti's Avatar
Re: Clutch master cylinder support
Would like to know also.
Old Sep 27, 2022 | 11:06 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Kinda rough but should be enough to make a reinforcement plate.
Old Sep 28, 2022 | 07:25 AM
midias's Avatar
Thanks helps a ton
Old Sep 29, 2022 | 11:29 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
How much difference do these really make? Just curious. Were they only on the later years? I ask because it seems like for all my time being here I didn't hear about them and now I've seen several threads discussing them.
Old Sep 29, 2022 | 01:36 PM
Dens71TA's Avatar
It was used beginning in 1984 with the introduction of the hydraulic clutch on 3rd-gens. The firewall is made out of rather thin metal and the reinforcement plate prevents cracking around
where the clutch master cylinder is attached. There are also two bars that go from the pedal pivot bolt to the firewall for further support.
Old Sep 29, 2022 | 03:49 PM
Car: 1983 Z28
Ok gotcha, yeah when I did my swap I thought it was fairly rigid due to the two support bars making a triangulated support. I guess every little extra bit helps though.
Old Sep 29, 2022 | 10:53 PM
midias's Avatar
I am definitely going to be adding one to the new body no way I'm going through all this trouble to paint the damn thing and then have my firewall crack on a very clean chassis
Old Oct 16, 2022 | 10:04 AM
midias's Avatar
Thanks for the help guys my friend and I made a new plate today and got it welded into the body.
TwinTurboDMAX
Jul 25, 2012 02:43 PM
devildawg
Jun 17, 2002 02:39 PM
birdofprey83
May 29, 2001 09:03 PM
