Broken shift button rod
Old Oct 3, 2022 | 06:59 PM
Wily85Z28's Avatar
Car: 1985 Z28
Hey y'all,
The rod that connects to my shift button has broken. I've been looking for a replacement and see that there are different plastic rods. Some are flat (like mine) and some are round. On eBay, they show as being for different years. Do they all work regardless of year? Would one from an '90 Z28 automatic work on my '85?
Thanks in advance!
Old Oct 3, 2022 | 08:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Broken shift button rod
Stick to the flat bar. The button has a clip on it that snaps onto the flat portion.
Old Oct 4, 2022 | 08:41 PM
Wily85Z28's Avatar
Car: 1985 Z28
Are you suggesting that because I would have to change the shifter **** and button or because the whole assembly won't bolt in correctly? FYI: I don't mind changing the shift **** and button.
Old Oct 4, 2022 | 08:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The later button/**** are integral and uses a U clip on the side to to hold down the ****. Early types w/ the ball/button that separate use a c-clip under the button to hold the **** in place. The two are not compatible, unless you swap the whole shifter assembly.
thwk
Jul 15, 2019 09:11 AM
Roger Minnick
Feb 10, 2017 05:37 PM
JonOMac
Mar 20, 2012 09:09 PM
86irocu
Nov 23, 2007 06:14 PM
