9 Borg Wagner: Oil route to axle bearings ?
Old Oct 17, 2022 | 08:44 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
Does anyone know the route of the oil from the limited slip differential to the axle bearings?
When filling the differential compartment with oil, how does it reach the axle bearings?
Old Oct 17, 2022 | 10:38 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: 9 Borg Wagner: Oil route to axle bearings ?
At about any speed those spinning gears throw that oil everywhere and some will go down the axle tubes to the bearings. Those roller bearings don't need a big flow of that lube.
Old Oct 18, 2022 | 04:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Also, when the oil heats up it will expand. Iirc, the oil level is right around the axle tubes bottom so when it gets hot it'll make it down the tubes. Also, going around corners will send some down the tubes. They don't need much at all
ajStyles2015
Aug 25, 2013 06:38 AM
GTandy
Jun 7, 2013 09:58 AM
BPWilliams
May 27, 2009 05:24 PM
firebirdman
Oct 10, 2008 12:55 AM
Momar
Nov 19, 2002 02:38 PM
