aftermarket t56 problem noise in nuetral
Old 01-20-2002, 09:48 PM
dsavio's Avatar
I just got it in and running and i left the old throw out bearing in it was maybe a couple of months old. and i left the new centerforce clutch. and now i have noise in nuetral. like the throw out bearing is done. did i need to lube something i didn't? i lubed the splined shaft but not the yoke thing bolted to the facce of the trannt it goes over the shaft about half way. I'm thinking maybe the throw out bearing rides all the way up there. I'm not sure there were no darn instructions. any one help please?? I guess im pulling the tranny again.
Old 01-21-2002, 11:04 AM
1987gta's Avatar
Can you describe the noise with more detail? (clatter, squeling, etc...) What fluid did you use in the tranny, and how much? I am guessing that the noise goes away when clutch pedal is pressed in.
Later,
Joe
Old 01-21-2002, 01:01 PM
dsavio's Avatar
Noise in tranny
Joe
The more i check it out the more it seems engine related. it does seem noisy in neutral after the car has been run. when you push in the clutch it goes away. it is a whrrring type of sound i used dexron 2 just like the sticker on the side of the tranny said and i put in 4 quarts.
Dave
theshackle
09-17-2020 08:26 AM
xxx3man`
09-23-2015 10:37 PM
B_Dubya
08-26-2015 05:09 PM
sreZ28
08-14-2015 07:48 PM
hokis
08-09-2015 03:57 PM
Quick Reply: aftermarket t56 problem noise in nuetral
