Car won’t go into park
Old Jan 17, 2023 | 05:36 PM
rednax's Avatar
Hello,
I just bought a 92 Camaro RS and have been working through it slowly. Today I took off the center console to clean it. After I put it back together the car will not turn over now. It seems like the car is not reading that it is in park and the temp gauge shoot all the way to the right when I turn the key. Any help would be greatly appreciated.
Old Jan 17, 2023 | 06:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Car won’t go into park
Originally Posted by rednax
Hello,
The temperature gauge is supposed to peg to full hot when you turn the key to the start position as a "Gauge test", so that's normal and not a part of your problem.
If you didn't take the shifter apart, perhaps you knocked the switch that's mounted to it loose somehow (or perhaps it's wiring connector).
Try this, WITH YOUR FOOT FIRMLY ON THE BRAKE, AND THE PARKING BRAKE ENGAGED, put it in neutral and try to start it. If it still don't start, move the shifter slightly back & forth around the neutral position while holding the key to the start position.
Chevyrider408
Northern California
17
Sep 10, 2011 11:48 PM
lagunacell
Jun 20, 2011 07:45 PM
Fattys
Aug 2, 2009 08:19 AM
Boogie123
Jun 22, 2006 07:04 PM
Mike92RS
Jun 12, 2002 03:33 PM
