Axle spline count?
Old Aug 27, 2023 | 10:31 AM
GypsyTroubador's Avatar
Axle spline count?
New member,I have an 88 iroc my brother is currently putting together.It has the G80 rearend code and I want to replace the axles with strange engineering components but I am unable to narrow down the spline count by researching online.Can anyone tell me based on the fact that it is the G80,10 bolt,posi,limited slip,what is the likely spline count for the axles?
Old Aug 27, 2023 | 02:02 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Axle spline count?
I'm pretty sure they are 26 spline, later years 90-92 used 28 spline. 89 was the transition year from 26 to 28
Old Aug 27, 2023 | 06:18 PM
Yup, 88 is almost certainly 26-spine, if the rear is original to the car. Transition began in the latter part of 89 production and was mostly but not quite entirely complete by the beginning of 90 production in these cars and others (e.g. S trucks) equipped with this model of axle.
Before spending money on 26-spline GARBAGE, check to see if his "G80" is still any good. VERY VERY VERY FEW are. It's most likely an Auburn; total POS, totally non-rebuildable, TOTAL GARBAGE. And that would be the GOOD possibility, since the other possibility would be the Gov-Bomb aka Grenade-Lock. Let's hope it's not that.
It would be the height of UTTER STUPIDITY to buy axles to fit that, then discover it's worthless, then realize that there's basically NO 26-spline carriers available, because nobody wants that GARBAGE, THEN have to go re-buy all 28-spline stuff.
In case you can't tell, I'm encouraging you to encourage your friend to update to all 28-spline stuff. New carrier along with the axles.
scooter
Apr 16, 2021 09:00 PM
morgans762
Jan 28, 2010 01:34 PM
AlkyIROC
Nov 24, 2006 07:59 PM
1fast91rs
Jan 31, 2004 09:34 PM
macxcrm114
Mar 27, 2002 09:21 PM
