28 Spline axles?
28 Spline axles?
Hello everyone,
I have been trying to find a set of used 28-spline axles for a 10-bolt in junkyards, but no one wants to part with them separate from the axle assy. Strange engineering only makes axles with c-clip eliminators. Does anyone have any axles or know who can make them???
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have an early 80's 7.5" axle out here, it should have same as you need, i would sell em if are same length and spline, if the snow crap weather would just quit, id pull the cover and yank the shafts and measure and count em. i was told its 3.42 or 3.73 axle, so..
what do you think ?
what do you think ?
Engine: 4.3L Z TBI
oh, i gues you hahve an 89, i guess that wont work, all i know is that the axle is an 82-87 axle, so,.. it came from something else I was told, because they wante dlower gear in the car, so,. car is 81 though.,
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Factory 28 spline axles that will fit will only be found in 90-92 third gens. I doubt you will find many of them in the junkyard since there weren't a lot of them produced.
You can buy much better aftermarket 28 spline axles from places like www.drivetraindirect.com or www.tomsdifferentials.com for $125 each. Part number KAC7-A7. They'll fit all third gen 10 bolt diffs with drum or disk brakes that have a 28 spline carrier installed.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
You can also buy a set of mosers from gearsareus.com for 215.00 bare. I just got mine from them, look real nice.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Don't forget Moser. I got a pair of 28 spline axles from them for somewhere around $270 including lug studs. Moser claims a strength of 30% stronger than stock.
Prodigious
Sep 18, 2015 05:23 AM
rudolphschenker
Sep 4, 2015 02:41 AM
