Correct tool- T5 drain plug pictures
Old Sep 9, 2023 | 05:03 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi,
Attached is a picture of my drain plug. It is slightly leaking around but still have about 3 threads to go. I can’ t get it to rotate anymore with my vice grips. The only ratchet I can get to almost fit is 3/4” (6point) but stripped it.
in another note, I need to replace the o rings of the speedometer cable. Do I need to pull the bullet completely out to replace it?
any advice welcome, thanks.
Old Sep 9, 2023 | 05:24 PM
NoEmissions84TA's Avatar
Re: Correct tool- T5 drain plug pictures
This is what you have for your oil pan drain plug???
That is not the correct plug. You are showing a pipe plug with NPT (tapered) threads.
Your oil pan uses straight threads with a sealing washer under the head of the bolt.
Old Sep 9, 2023 | 06:59 PM
podiatra's Avatar
Engine: 350 swap
This is the manual transmission drain plug.
Old Sep 9, 2023 | 07:57 PM
Ok then, use pipe thread sealant.
Old Sep 9, 2023 | 08:18 PM
podiatra's Avatar
Engine: 350 swap
Thanks!
another quick question since I will be under the car, I need to replace the o rings of the speedometer cable. Do I need to pull the bullet completely out to replace it?
Old Sep 9, 2023 | 08:20 PM
Best tool for that is one of these. https://www.homedepot.com/p/LTWFITTI...3810/313756880 Just one; not a 10-pack.
Old Sep 9, 2023 | 08:32 PM
podiatra's Avatar
Engine: 350 swap
Way better option…geez
Old Sep 9, 2023 | 09:41 PM
Oh I forgot... yes the "bullet" has to come out to get at the O-ring. There's also a little tiny lip seal at the top, where the cable inner core goes into it, and that fails ALOT. If you still have the stock chinesium "bullet" I STRONGLY urge you to just replace it. Needless to say it comes with all the rubber. Same one fits Turbo 350 so it's SOOOOOPER EEEEEEEZZZZY to get, for example https://transmissioncenter.net/shop/...-gear-housing/
Old Sep 10, 2023 | 10:39 AM
podiatra's Avatar
Engine: 350 swap
Thank you! Just ordered one…
Old Sep 10, 2023 | 06:29 PM
podiatra's Avatar
Engine: 350 swap
Quick update: i just removed speedo bullet and it drain some trans oil. Do I need to add oil to the tranny before I installed the new bullet? Can it be done thru the bullet hole?
Thanks!
Old Sep 10, 2023 | 07:44 PM
Should only have drained a floz or 2 at most. Probably not worth worrying about, since the T-5 version we have being "tilted", ends up accepting near an extra half quart compared to the same transmission in other cars when filled through that hole.
Sure, you can add some in the speedo bullet hole if you want, or into the main fill hole if you prefer. Butt, if fluid came out of there when you removed it, it probably wasn't low to begin with, and is probably OK afterwards, if only a little came out. All depends on how much got out.
Old Sep 10, 2023 | 08:27 PM
podiatra's Avatar
Engine: 350 swap
Thanks again.
Definitely more than 2 oz. More like a cup came out. I was expecting a lot less from what I have read.
Old Sep 10, 2023 | 08:42 PM
I guess that would depend on how you had the car positioned. If it was high in the front then no doubt more of the fluid would have run to the rear.
Let the car down, jack it up from the rear and support the rear with stands with the front sitting on the ground, pour it back in.
Old Sep 10, 2023 | 08:49 PM
podiatra's Avatar
Engine: 350 swap
Yep… it is slightly in the front.
Old Sep 15, 2023 | 01:54 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
search out a "recessed square," plug, which will take a 3/8" extension. Simplest and most commonly available.
Old Sep 15, 2023 | 05:28 PM
podiatra's Avatar
Engine: 350 swap
Thank you! Anything easier that pipe plug will be a big help!
LostX
Jun 5, 2012 01:45 AM
Maverick H1L
Dec 24, 2009 07:52 PM
Clou
Jun 9, 2007 10:04 PM
mrsuburban
Oct 15, 2006 03:09 PM
doc76239
Sep 9, 2004 01:46 PM
