Is my loose pinion nut causing a leak?
Old Oct 22, 2023 | 06:54 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
So I “fixed” the leak at the diff cover but turns out it wasn’t leaking from there at all. It is leaking from around the pinion nut, around the washer. There isn’t any play in the pinion and no whining. The nut is not loose either but it may have lost some tightness . I was going to attempt to fix this leak by smearing rtv all around the nut and washer but upon closer inspection I can move the washer behind the nut very easily. Does this mean the nut has come loose? What to do? Do I tighten it just a tad till washer doesn’t move anymore and then rtv it ? Use torque wrench?
https://youtube.com/shorts/3iGxrAjfbRQ?si=tXVjrnzQqUAYSHDC
Old Oct 22, 2023 | 08:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Is my loose pinion nut causing a leak?
There is a procedure for tightening that nut to put preload on the bearings, but for sure you should crank it down some to stop that leak and preserve the gears and bearings in the differential from damage due to slop in the set. When I replace a pinion seal I mark the nut and shaft before removing so I can put it back in the exact same place, then give it an added 10 degree turn to get that preload right.
Old Oct 22, 2023 | 09:29 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Well I gave errrh two ugga duggas with the impact. Pinion has slight more resistance then before when turned. Hopefully I didn’t tighten too much. Will test drive soon.
Old Oct 22, 2023 | 09:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
That's not good. You may have gone to far on the bearing preload.
The problem is fluid leaking past the yoke/ pinion splines and out from behind the washer. Pretty common and it really needs to come apart a bit to re-seal that..
Old Oct 22, 2023 | 10:49 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
I used this procedure on my 10 bolt and it worked perfectly https://www.thirdgen.org/forums/tran...al-change.html
Old Oct 23, 2023 | 10:33 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Damn let’s say I did overdo it. What would happen? What kind of noises would I hear. Seems like a great time to finally buy some gears and tackle a diff job once and for all .
Old Oct 23, 2023 | 12:01 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
About the only thing that you'd damage would be a bearing, and they are pretty tough to start with. You might start to hear some quiet grinding type noise or hear some new gear whine when letting off the gas. I doubt you'll have any problems though.
Old Oct 23, 2023 | 12:03 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I sure like that drive train in your car though!
Old Nov 19, 2023 | 07:11 AM
Camaro71's Avatar
You might or might not have overtightened the nut > resulting in too much pinion bearing preload which could lead too overheating. This might also have changed the pinion to ring gear distance and might lead to hauling.
But.... most of the time the specs open up over time leading to problems as well, so you might have just closed it up and be lucky, time will tell.
Your problem is most likely caused by oil sipping between the pinion to yoke splines. I always apply some RTV to the inside of the yoke to prevent this from happening.
Old Nov 19, 2023 | 07:30 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
So far so good. No noises but still seeps a bit of oil. Pretty sure I overtightened. It has some slight rolling resistance on small inclines, where before my car would keep rolling in neutral to a smooth inertia filled stop, now it just rolls and stops abruptly. Not as much freewheel. I noticed this too after tightening the nut, pinion was slightly harder to turn. Well no noises yet but I’ll keep an eye on this perdition experiment. I bet it’s not too late to pull out and set up right with another crush sleeve
JamesC
Jul 9, 2021 08:24 PM
steveusaf
Jul 13, 2020 11:08 AM
Faolan
Aug 2, 2017 07:29 PM
kozman
Dec 22, 2009 10:38 AM
Mike92RS
Feb 18, 2005 12:57 PM
