BW 9-Bolt Ring and Pinion Gears
Old Dec 6, 2024 | 05:04 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I just picked up a BW 9-bolt posi rear with 2.77 gears from my local Salvage Yard to rebuild with the TLVL 3-series carrier for my 1989 GTA. From what I can see, the only gears available are 3.70. Is this truly the case? I wanted to rebuild it with either 3.27 or 3.45 to go behind the WCT5 trans, but it seems these ratios are non-existent. Can you guys confirm? Or point me to a source?
Interested if anyone has a good used set lying around collecting dust as well...
Thanks.
Old Dec 6, 2024 | 07:44 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Re: BW 9-Bolt Ring and Pinion Gears
There was a set of 3.45 on market place not too long ago. The seller is in Canada. Might try looking there.
Old Dec 6, 2024 | 08:50 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Wow, that was a lot to look through! Only found one potential, thanks for the pointer!
~Tim
Old Dec 8, 2024 | 07:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
This thread is pretty interesting.
https://www.thirdgen.org/forums/tran...installed.html
Old Dec 8, 2024 | 08:40 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Interesting indeed, I've been following...
I just brought home (today) two rusted out BW 9-bolt rears, both with 2.77 gears and the older '85-87 disc brakes. I've never rebuilt a rearend, but I've got a couple rebuilds to knock out in my future! I already ordered a TLVL from Dave at Supa-F Spares last week and just minutes ago I ordered a 3.45 gear set from 9-bolt.com. I've heard 9-bolt.com isn't active anymore, but my order went through, so we'll see. If anyone is interested in some highway 2.77 gears, hit me up!
I'm stripping down one of the housings tomorrow and will be having it powder coated before I start the rebuild. In the meantime, I'll get everything ordered from Ratech. Thanks to General Disorder, KeyKey, and others!
Old Dec 9, 2024 | 11:23 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
In the states, only 3.70 ratio gearsets are available. 9-Bolt.com is out of Australia and has other ratios they can get, assuming they are still active. Also will need a 3-series carrier.
If you can’t source the parts from 9-Bolt.com, you may be better off finding a GM 10 bolt rear and building that.
Old Dec 26, 2024 | 08:43 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Just to eliminate any doubt, 9-Bolt.com is still active! I hesitantly ordered a 3.45 ring and pinion gear set from them via Paypal on their website and it actually showed up today! No other comms other than shipping confirmation. I now have two spare 9-bolts, both with Delco Moraine brakes, a set of 3.45 gears, a set of 3.27 gears, and two sets of 2.77 gears. One 9-bolt has the smaller pinion bearing and came with the 2.77 gear set. Both disassembled now, but I'm definitely going to rebuild the "common" pinion bearing rear with the 3.45 gears.
The 2.77 gears are available if there's any interest - LMK. I think I'll keep the two spare 9-bolts for future projects...LOL!
The B-Man
Aug 31, 2011 11:08 AM
jbpnumber03
Nov 5, 2007 01:43 PM
TMZIrocZ350
Oct 3, 2007 08:55 AM
92rs85berlintta
Sep 6, 2003 06:49 PM
