Case spreader for a dana 30?
Old Apr 13, 2025 | 10:07 PM
lakehoon's Avatar
Any one know if the cheap vevor case spreaders for dana 30..etc will.work for the 7.5" gm rear end?
Old Apr 14, 2025 | 09:45 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Case spreader for a dana 30?
Why are you trying to spread a 10 bolt ?
Old Apr 14, 2025 | 09:47 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I was wondering the same thing myself too.
Old Apr 14, 2025 | 09:55 AM
lakehoon's Avatar
considering trying to install new ring and pinion for first time. Ive removed carriers to install.lockers and service inner seals in dana 60's and 14 bolt ff by freezing them. They always came close reusing the same shims. But never started from scratch with new gears.
Old Apr 14, 2025 | 10:00 AM
Engine: Lb9
Transmission: M20
sounds like a good way to destroy a 10 bolt
Old Apr 14, 2025 | 10:01 AM
lakehoon's Avatar
why is that?
Old Apr 14, 2025 | 10:15 AM
Engine: Lb9
Transmission: M20
Your suppose to use a dial indicator .There is a spec limit . Remember excessive stretching of the housing will lead to permanent distortion . If you’re having issues removing the carrier you can put a wrench on a ring bolt. Turn the pinion until the wrench pushed on the housing. Then slowly rotate the pinion the carrier will walk out.
Old Apr 14, 2025 | 10:20 AM
lakehoon's Avatar
Gotcha, i havnt even started to try or even have any of the parts yet. Just been doing some researching before i buy the parts.
Old Apr 14, 2025 | 12:57 PM
All the case spreader is for, is to widen the space where the carrier goes, so you can put it down into there, then the case is supposed to close back up and put preload on the carrier bearings. Has nothing to do with the gears themselves, new or old, in any manner way shape form or fashion, nothing to do with setting backlash, and nothing to do with removing or installing bearings to the pinion or the carrier itself.
There's other ways of doing that, that don't involve warping the pumpkin in the very place where it's already the most vulnerable and the most likely to allow gear misalignment and failure.
Old Apr 14, 2025 | 02:53 PM
lakehoon's Avatar
I'm aware of what it does. I usually put them in freezer when removeing and installing carriers. But when setting up new gears it makes it easier adjusting to get the correct pattern. Instead of fighting it everytime
Old May 6, 2025 | 09:52 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Did you try it out? I too am curious if it can work for this application.
Old May 7, 2025 | 02:23 AM
lakehoon's Avatar
I havnt, did alot of research couldn't find a definitive answer. But seemd like it wouldn't work with other applications etheir. Not to that point yet. But when I get closer I'll dig into it a bit more.
marauder101
Jan 1, 2025 03:47 AM
hitmanb88
Mar 14, 2023 01:54 PM
raaneal
Canadian Region
Feb 5, 2017 08:45 AM
KNIGHTE
Jun 30, 2015 12:58 PM
ck76239
Dec 7, 2005 11:12 AM
