700r4 shift shaft seal direction
Car: `86 SS / `87 SS
Re: 700r4 shift shaft seal direction
Spring goes against the oil side.
if the unit had internal pressure, the recessed area where a spring is typically found goes against the oil and internal pressure would tend to help seal lip stay against the shaft.
The shallower ramp-up angle to the seal lip starts at the outside and goes"up to the lip at a lesser angle than the oil side. Don't confuse a second dust lip with the oil seal lip; output / yoke seals very commonly have double lip seals like this.
Cpritch1
Dec 7, 2009 10:03 PM
phess11
May 1, 2003 09:08 PM
