How to remove T5 trans to bellhousing passenger side upper bolt
Old May 26, 2026 | 04:30 PM
Vivalafelix's Avatar
Hello I am currently pulling my trans out of my 87 V6 with the T5. I removed 3/4 of the trans to bellhousing bolts but am stuck on the upper passenger side bolt as its in a inconvenient location. Can anyone give me guidance how they managed to get it out? Thank you
the bolt is circled in red
Old May 26, 2026 | 05:23 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: How to remove T5 trans to bellhousing passenger side upper bolt
A 20in(or so) extension w an angle buster/u joint.
Old May 26, 2026 | 06:44 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
That bolt can be removed with a torx, yes? Iirc, it's near impossible with a regular socket. But yeah, long extension with a wobble. I use an extension that has a wobble built into it.
Old May 26, 2026 | 11:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Crack it free with a socket / extension.
Spin it out with a Torx.
Ever see another hex / Torx bolt? They knew.
Old May 27, 2026 | 09:43 AM
Yup, it's kinda behind those "features" of the casting.
That's why those have a Torx in the first place. A socket won't go in there. A wrench might butt they're not gonna stand there swinging a wrench on a production line. So they put a Torx bit on their hydraulic driver, so they can zap em in there in a half-second or whatever. They couldn't give a rat's reeking buttocks for your inconvenience taking them back out while laying on the floor of your garage; that's your problem, not theirs. Jerks.
Not sure those are regular Torx. They may be "Torx Plus" instead, like the bolts that hold a 4L60E bell housing to the case. Exactly the same except slightly different. I don't really know butt it would be worth checking.
Old May 28, 2026 | 07:51 PM
I finally got if off today for those interested this is what worked for me:
15mm 1/2" drive stubby socket, then a 3" extension, then a u joint socket, then 10" extension, onto a 1/2" ratchet with a metal pipe around it for leverage.
calh223
Mar 31, 2026 09:00 AM
isaacim
May 25, 2015 10:18 PM
steves85
Sep 7, 2010 09:36 AM
Darkshot
Aug 16, 2009 03:07 PM
RK82
Jul 13, 2008 11:14 PM
