Can B+M shift kit be changed to Transgo
Old Jan 29, 2002 | 11:16 AM
Bob S's Avatar
Currently have the mild B+M shift kit in my 87GTA and was wondering If it could be swaped out and a Transgo installed.My major concern is the modifications already done to the plate between the valve body and housing.
Old Jan 29, 2002 | 02:12 PM
transfixleo's Avatar
Yes you can replace the B&M (NON) SK with the TransGo but you will need to order a new separator plate since the B&M ill be hogged out quite a bit.
Old Jan 29, 2002 | 02:19 PM
Bob S's Avatar
thanks for the reply.Is there a peticular transgo kit you would recomend?And I hate asking but how much do you estimate $ for kit ,corvette servo ,and replacement seperator plate.Also is there anything else I might need?Thanks again.
Old Jan 29, 2002 | 02:24 PM
Bob S's Avatar
Oh I should also mention its a late 87 style with the aux valve body.
Old Jan 29, 2002 | 02:35 PM
Pro Built Automatics's Avatar
You could use my HD Trans-Go Shift kit with the Corvette servo, both boost valves, & a seperator plate for around $90.00. Let me know?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
