T-5 to 700R4 conversion question
Old Feb 3, 2002 | 09:27 PM
89 Drop Top's Avatar
Car: 89 RS Convertible (Original owner)
Axle/Gears: 3.73 With Zexel Torsen Ltd. slip
I'm converting a 85 Iroc that originally came with the T-5 Manual tranny to a 700r4 tranny. Is there anything I should be aware of during this swap?? I got the car from a friend, and he pulled the engine & tranny out of it before I got it. I'm going to be installing the engine & tranny in the car, & just wanted to know if anyone else has done this, and can offer any advise, parts that will be needed ( I know I'm gonna need the shifter assy., shift cable, and tranny cross member). anything else??
Thanks!!
Derrick
Old Feb 3, 2002 | 09:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hey,
i did this swap on my camaro. It wasn't easy but i think that it was worth it. You will definately have to patch that hole in the floorboard. I used a piece of steel that i bought from a hardware store. Try to buy some that is the same thickness as the floor itself.....if you have any questions feel free to e-mail me.
Old Feb 4, 2002 | 03:23 AM
Jza's Avatar
Jza
The computer. The pedal assembly, unless you want a useless clutch pedal there to fake out unsuspecting drivers (no, no, you gotta push in the clutch to drop it into D). I guess you'll need the flywheel as well, unless all that's already bolted together (you got the engine/tranny together).
Old Feb 4, 2002 | 08:30 AM
Thanks for the quick responses guys. If anyone can think of anything else I might need, keep it coming!!!Can't wait to meet some of you at SLP day in E-town!!
Derrick
Old Feb 4, 2002 | 01:22 PM
EddieDellz's Avatar
why would you want a auto when the cars allready set up for manual aww well thats cool whaver you want .. something that concerned me tho .. i thaught 85 iroc wasent avalible in manual that you couldent get tpi and manual :T am i wrong?
Old Feb 4, 2002 | 02:16 PM
Eddie, The guy I got the car from had already pulled the original motor & 5 speed tranny from the car. I wouldn't mind having the 5 speed either, but I have a freshly rebuilt 700r-4 tranny sitting in my garage with an SLP shift kit installed in it. It was gonna be a back-up tranny for my convertible, but (knocking on wood here!! ) It just won't die, although it's probably due for a freshining up (it has over 150,000 miles on it though). The '85 coupe I'm building originally had the compu-carb engine in it, so I couldn't answer your question about the avalibility of TPI & the 5 speed, although I know that you couldn't get the 350 with the 5 speed.
Thanks again guys!!!
Derrick
Old Feb 4, 2002 | 02:30 PM
EddieDellz's Avatar
Its understandable i would do the same .. if i was still in ny id hook you up with my t5 unfortunatly in my wyoming at school i come home to ny in june tho when i get home i plan on rebuilding my 700 in my firebird at home and getting some other stuff done for engilsh town this year hope to see ya there
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
