89 Tranny in 85
Old Feb 5, 2002 | 09:57 AM
texasgt's Avatar
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
89 Tranny in 85
Need some quick help. I am replacing my original tranny in my 85 LB9. I found a good one on EBAY from an 89. I thought that because I have a 2 piece rear seal that I need to make sure that the new tranny also has a 2 piece seal ? This 89 700r4 is completely rebuilt with aftermarket parts .This guy beleives it will fit. I disagree, AM I wrong ?
Old Feb 5, 2002 | 05:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The trans does not care about the seal.
I have a 91 T-5 in my 83 car. I also used to have the same 91 trans behind a 73 model 400 motor.
Old Feb 6, 2002 | 12:20 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: 89 Tranny in 85
The only thing is you can't use is the flexplate[flywheel] , all you have to do is get one for a two piece seal engine.
Old Feb 6, 2002 | 05:54 AM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
the 1985 is a two piece rear main seal. the trans.\torque converter will bolt directly to your existing 1985 f-plate as long as its in good shape. replace it with the same part as spec.'ed out for your 85 and i think most aftermarket f-plates are drilled for both t converter bolt configurations nowadays.:lala:
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
