Will any T5 fit in my car???
Old Feb 14, 2002 | 11:57 AM
jasons86iroc's Avatar
Acctually i have an 86 iroc but my rother has an 88 mustang GT. His tranny busted some gears, so, i need to know will a camaro T5 fit in his car, or is there any other car that shares that same tranny.
I know this is not thirdgen but he is my brother and i want to help him out.
Old Feb 17, 2002 | 02:49 AM
812MANY's Avatar
I bought a Mustang ('93 GT) W/C T5 for my Camaro, but the bell to trans bolt pattern and the cutout in the bell were different. Also, the tranny in the Fbody is tilted 17*, so you won't be able to bolt the crossmember up.
Sorry, but No Dice.
JK
Old Feb 17, 2002 | 07:30 PM
TexasLT1's Avatar
Car: '92 RS
thats just the bellhousing though. get the camaro bellhousing and it should bolt right up. but I think the input shaft on the 'stangs is different, so you might as well get one from an f-body.
Old Feb 17, 2002 | 07:47 PM
87RS402's Avatar
No, a T-5 from a camaro will not fit a mustang,and vice versa. The front and rear housings are different as well as the input/output shafts.
Old Feb 17, 2002 | 11:30 PM
Bill86Z's Avatar
Mustang T-5s have no torque arm holes. that is the main thing.
Old Feb 18, 2002 | 10:55 AM
okay, so i won't bother telling him he can do it, for some reason it seems as the ford T5's and crap, and around here you can't find any for under $600.
Thanks for the responses
Old Feb 18, 2002 | 05:53 PM
812MANY's Avatar
No, the chevy bellhousing WILL NOT bolt up to the ford transmission.Also, the imput shaft on the ford is about 11/16" longer than the chevy. You COULD meake a spacer with both patterns and thick enough to make up the difference in imput length, but you've still got the outputspline and torque arm mounting problem.
Old Feb 18, 2002 | 11:13 PM
TexasLT1's Avatar
Car: '92 RS
my bad, just my ignorance coming out I guess. Ive never actually looked at the two, I guess I was just assuming.
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
matthew911
Aug 12, 2015 09:38 AM
armybyrd
Aug 10, 2015 09:23 PM
