T-5's Power?
Old Feb 19, 2002 | 07:55 PM
ta350400's Avatar
T-5's Power?
Does anyone know how much horsepower and torque a stock T-5 will hold?
Old Feb 19, 2002 | 09:24 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
depends which one. If you have the World Class, that can hold up to the rated 300 lbs of torque. If you have the older one, I belive these were rated at 265. Either way, if you bolt a healthy 350 to it, it won't last long.
Old Feb 19, 2002 | 10:50 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
The WC T5-Z will hold 330 ft/lbs. I think that's as high as the T5 goes until you start talkin about the Tremec.
Old Feb 20, 2002 | 10:33 AM
ta350400's Avatar
Hey thanks guys i only plan on running it until i have the money for a T-56. I am dropping my 355 in this weekend. Let the fun begin.
Old Feb 20, 2002 | 12:47 PM
Astro's Avatar
Actually, the T5 should hold up to about 300 lb-ft and the WC T5 somewhere in the neighborhood of just over 400 lb-ft. The number for the world class is according to my mechanic who just rebuilt my WCT5 and is a transmission specialist. And since a lot of 87 & 88 models with T5s are pushing near 300 lb-ft of torque I highly doubt they can only handle about 265.
Old Feb 20, 2002 | 03:08 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Then your transmission specialist must be an idiot. Because The Tremec 3550 / TKO handles 400 ft-lbs. The regular WC is no where near as strong as the Tremec.
I just bought a T5-Z and the rating on it was 330 ft-lbs, that's the most a T5 will take until you start talkin about the TKO's and T-45's.
Old Feb 20, 2002 | 03:11 PM
AggieZ28's Avatar
285lbs of torque.
either way its not much.
better off with something else....
Old Feb 20, 2002 | 04:21 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I dont' know where these engineers come up with their torque rating and HP # limits, but I've got a 92 WC T-5 in my firebird and my car runs solid low 13's and I beat on the car pretty much on a daily basis ....tranny still shifts perfectly, and I've had this setup for over a year (had the tranny for 3 years, swapped in the vortec setup a year ago). I'm fairly certain my TQ #'s are well over 300 with the trap speed I'm getting. HOWEVER.....If you don't have very sticky tires I think it makes the tranny last longer cuz my tires (eagle GS-C) don't hook up for **** and I can just about spin em through 4 gears if I'm really powershifting like I do at the track. So I guess everything depends on your setup. But unless you are running some REALLY sticky tires, like Nitto drag radials or something, you are pretty safe running a WC T5 with a healthy 350.
Chris
Old Feb 22, 2002 | 04:17 PM
David 91RS/Z28's Avatar
I beat up on mine pretty good as well. Many 12 second passes and 115K miles on the tranny. It's taking about 480ft lb's quite nicely IMO!!
Old Feb 23, 2002 | 09:24 AM
DM91RS's Avatar
Car: 91 RS
The shock loads are what gets them. I know a guy with 500+ hp 350 that runs roadracing slicks (14") and runs a 89 model T-5. He claims to have broken everything but the T-5. His advice to me was to run syn lube and never, ever power-shift the thing.
You also have to check the shim clearance for the input-output shaft and keep it at the min for the best results.
Old Feb 24, 2002 | 04:44 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
I have over 400 lbs of torque and still running the original 84 T-5 with BFGoodrich Drag Radials. I don't expect it to last a lot longer though, and my clutch does slip a little bit in first gear which probably helps to keep my tranny alive.
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
Cacike
Aug 27, 2015 05:10 PM
sailtexas186548
Aug 24, 2015 10:11 PM
