700r4 trans brake
Old Feb 23, 2002 | 03:17 PM
nickyg's Avatar
Car: '91 TA Green
700r4 PROBLEM! attn:probuilt or tranfixleo
Hi everyone. I am a new member, but I have owned f-bodies since 1978. I currently have a 1991 T/A. 305 tpi with a 700r4 trans, 102000k miles, all else bone stock and in excellent condition. I recently started having a slight problem, I believe, with my trans. Upon acceleration, it shifts up through the gears beautifully as normal. But when I let up off the gas, the RPM'S drop down almost to idle instead of slowing down the car as normal with trans braking. This only happens in gears 1-3. In overdrive, it still trans brakes. I had the filter and fluid changed about 5000k ago. Fluid level is fine and does not smell at all. The TV cable is adjusted properly. I brought it to a trans shop. They took it for a drive with me. Upon returning to the shop, their first and only diagnosis and solution was a total rebuid to cost anywhere from 700-1200 $'s. This supremely pissed me off. I then consulted a retired trans guy friend of mine and he said that he thinks that the problem could be a stuck unloader valve. He recommended to first try some liquid trans fix like Lucas Products. If that didn't help, try to find a shop that would bebuild my valve body which would be a significant savings as opposed to a total rebuild.I tried the trans fix fluid, but no change. I would appreciate if any members could help me with this particular problem. I live in Middlesex county, NJ. If anyone knows of a trans shop in the Edison area that isn't a damn sheister looking to retire on one repair and who would be willing to do a valve body rebuild with a TRANSGO kit please let me know.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Aug 6, 2015 04:15 AM
