Trans Go Kit
Old Mar 3, 2002 | 11:39 AM
MINN IROC-Z's Avatar
Car: 1988 IROC Z
Trans Go Kit
I am looking at a Trans-Go kit in Summit to improve my shifts on a 1988 IROC. Are these kits very hard to install with out prior knowledge of transmissions? I don't want to order this kit unless I think I can install it. My problem is that the 2-3 shift is very sluggish when I am racing it in town and would like to make it so I can shift it both manually and just let it shift automatically like normally. I have done quite a few modifications to the engine but now need to firm up the transmission to compliment the engine. I would appreciate your honest answers and thank you for your help. Dennis
Old Mar 3, 2002 | 12:10 PM
Jay 727's Avatar
I hear the transgo kit will help this but the real problem is the 3-4 clutch stack clearance is too big (factory specs).
I used to have a bad 2-3 flare until I took the trans apart and changed the clearance from .080 to about .030, it's a lightly modified 700 with no shift kit and works flawless now. I also drove a 1/4 valve body checkball into the third accumulator feed hole. (similiar to a mod in a transgo kit).
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Mickeyruder
Sep 2, 2015 02:45 PM
dhonda200
Aug 11, 2015 11:50 PM
