Rear End Gasket Question...
Old Mar 4, 2002 | 07:20 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Hey,
This spring I will be draining my rear end and adding synthetic gear oil, posi additive...
I called my local GM Dealer and asked for a rear end gasket...his question to me was:
What size? 7.75" or 7.625" ??
I told him I had the 3.27 9-Bolt Borg & Warner rear but that never helped him... he said he showed two part numbers.. the 7.75" and the 7.625"
How am I going to find out what size mine is?
Old Mar 4, 2002 | 10:58 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt is a 7.75. How much did they want for the 7.75 gasket?
Old Mar 4, 2002 | 11:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't waste your money at the dealer on any of that. Use the "tubular style" gasket.
Old Mar 4, 2002 | 11:28 AM
87ROCZ's Avatar
Hey RB83L69
What exactly is a "tubular gasket"???
Old Mar 4, 2002 | 12:38 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Re: Hey RB83L69
It is called RTV gasket maker, and it comes in a tube that you squeeze it out of...
Lots cheaper than a gasket, and much easier to scrape off when you have to service the rear again.
Old Mar 4, 2002 | 03:34 PM
ede's Avatar
ede
well i guess i'll disagree with rb on this one, i prefer to use a gasket and not RTV. i even use the china wall gaskets.
Old Mar 4, 2002 | 04:07 PM
arthur's Avatar
I am not 100% on this one, but I don't think that there is any gaskets for the 9 bolt readily available. You could always make one, but a good gasket silicone will work just as well if not better. Just do not apply too liberally, and createwads of silicone inside the diff housing!
Old Mar 4, 2002 | 05:17 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
There are now readily available. I will be adding to my page later this week along with a bunch of other 9 bolt parts.
Miles
www.9bolt.com
Old Mar 4, 2002 | 11:37 PM
mechanicalmehem's Avatar
lol, at dealerships like where i work we use both, the sealer usually lasts longer if it is cleaned up well:lala:
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
