Custom Built rear
Old Mar 14, 2002 | 03:59 PM
Minion's Avatar
Custom Built rear
How much would it cost to have a shop build me a 9 or 12 Bolt rear? TO stand say 600 HP worth?
I see already built ones for around $2,000 would this be typical?
And if I remember right these were wo/ brakes.
Or should I just get a forth gen rear and by new wheels and front spacers?
Last question, How much power can the 3rd gen 9-bolts (Borg-Warner) take?
Minion
Old Mar 14, 2002 | 07:18 PM
ede's Avatar
ede
easiest thing to do would be to buy a 9" or 12 bolt from moser, over 2000 i'm sure. you aren't going to find too many shops that will want to relocate all the brackets to a 12 bolt or 9" and fabricate something for the torque arm as well.
Old Mar 14, 2002 | 07:39 PM
Momar's Avatar
The bw 9 bolts are supposed to be able to take quite a bit. Talk to 88 427 CAMARO. He said he has been running a stock 9 bolt behind a 500hp 520lb 427 for I think over 3 years.
Old Mar 14, 2002 | 09:37 PM
Minion's Avatar
Would the brackets be the same form a 9" Borg warner as on my 92RS? Or would they have to be relocated?
Old Mar 14, 2002 | 09:40 PM
Momar's Avatar
It is a 9 bolt, not a 9 inch, and it is a direct swap. The brackets are the same.
Frozer!!!
Jan 19, 2024 04:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
