Speedo Gears problems!
Old Mar 17, 2002 | 12:39 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I changed my speedometer gears today and had a few problems. The first problem that I had was that the clip that holds the “drive” gear on the output shaft broke. I went to the dealer and they said they don’t make that clip anymore so I just put on the “drive” gear on without the clip. It work or for like 5 min and now my speedometer doesn’t work. Where can I buy that clip???
The second problem was when I took off the old gear on the speedometer cable and put the new one on it slid to close to the sleeve on the rod. The old gear sat toward the end of the rod, the new one sits as close to the sleeve as possible.
Old Mar 17, 2002 | 10:27 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I just picked up the clip and gears at the junyard, you need that clip to keep gear in right location
Old Mar 17, 2002 | 11:12 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
thanks "coxy". Has anyone experienced my other problem with the gear that goes on the shaft that connects to the speedometer cable, where the gear slides to far back on the rod? It's hard to explain. So I here illustration:
How original gear sat onthe rod:
How new yellow gear slides back:
I think this is the problem that the gear is just sliding to far back. Anyone have this problem?
Old Mar 18, 2002 | 07:33 AM
Beast4's Avatar
There have been over the years many different combinations of speedo gears for various xmissions all using color coding. Sounds like you might have the right color gear but not for the right tranny. I would think that the different position on the "rod" would be an issue.
You definitely will need a working clip on the output shaft!
What level of competence does the local dealer's parts department have?
Old Mar 18, 2002 | 07:43 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
WHats up?
I had a problem with my 3.73 speedo gears sliding in the direction of the trans after installing it. Even with the clip installed, the gear on the output shaft continued to slide toward the trans side of the output shaft TRANNY SIDE EXPLANATION= ( when u take the tail section of the tranny down & put the gear on the tip of the output shaft. The gear is starting off at the drive shaft side & u are pushing it towards the tranny. I hope that clears up the "TRANNY SIDE") Most of the time when the gear moves out of place some of the teeth get damaged so u will have to buy another set. I solved the problem by making sure the clip was installed in the right direction & checking to see that the gear & clip had locked into place on the out put shaft( its a really snug fit so sometimes u may think thats its positioned right but its not so u have to be sure its locked.) hope this helps u out
njdaewoo
Old Mar 19, 2002 | 07:32 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I hade to make a clip out of some metal i had laying around, that fixed it.
Old Mar 19, 2002 | 07:40 AM
Beast4's Avatar
Yeah, sometimes you've just got to do stuff like that :-).
Old Mar 19, 2002 | 05:21 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
HEY WAIT A SECOND!!!!! I just went to GM LAst week and ordered new speedo gears and THAT CLIP....Here was the ONLY issue I had...The GM Distribution center sells them in PACKS OF 10.... AND THEY CHANGED THE PART NUMBER.....Anyway the dude at the dealer who I always deal with called them up and they went ahead and shipped me 1 of each gear AND the CLIP....Sitting in my shop right now...
Sooo the parts are out there through GM but you need a service guy to take a little initiative to investigate what happened to it.... I paid 1 dollar and 15 cents for it...
MAybe I should just buy a 10 pack and sell them on here...LOL
Ill look for the Part number and post it if I can find my order slip...
Kenwood
1987 Vortech Supercharged GTA
Old Mar 19, 2002 | 05:25 PM
Beast4's Avatar
Kenwood
Yeah, that is why the comment earlier about how competent his parts man is. Have been down that road. A parts department that knows something is a rare and wonderful find :-).
Old Mar 19, 2002 | 05:44 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Yeah I locked on to a killer one...He snagged me some GTA Badges after they were discontinued and supposedly all ALLOCATED through GM...He got a center console for me when they were/still are on NAtional Backorder panding a vendor agreement, he Hooks me up whenever possible......Hell he spent a week Finding a specific LONG SINCE DISCONTINUED Cable set for my 1987 GTA....He fudged a vin number from a car sold in 1992 through the dealership to Make GM give the last one up to me... Literally I heard the phone conversations viaspeakerphone... I cant say enough about the guy... AND because of that I only buy GM stuff from HIM... He has been invaluable with helping me Get all of these otherwise impossible to find parts....Tons of supposed discontinued stufffor my vette as well.
The dealer I used to go to would just say..."UHH THey dont make it anymore........NEXT"...Thats why (I dont make it anymore....OUT to that dealership that is...
Kenwood
Jorlain
Aug 24, 2022 05:11 PM
junkcltr
Aug 2, 2019 11:12 PM
beachrodder
Aug 7, 2015 04:27 PM
