Does anyone make a locker for 9 bolts?
Old Mar 20, 2002 | 07:33 PM
southerniroc's Avatar
I made the mistake of heating my drag radials up on uneven surface and shattering my spider gears. I don't know how bad they are shattered, but there was little pieces of metal in the bottom of my rearend when I pulled the cover off.
I have raced the car two weekends in a row after that happened(didn't know that I had shattered my spider gears) with no noise off the line. When I got home I noticed it made a loud clanking noise when I put in reverse, so I decided to pull the cover off and there it was. Can the carrier be rebuilt or do I have to get a whole new carrier? If a new carrier would be the best way to go i would rather get a Detroit Locker or something like that, because it's not a daily driver and they are alot stronger.
Old Mar 20, 2002 | 08:12 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've got mini spools available along with individual pinion gears (aka spider gears), series 3 posi carriers, gear sets up to 4.10 ratio and lots of other stuff for 9 bolts. If you don't see it on the page, just ask, as the page (web site) is going through renovation this week.
Miles
www.9bolt.com
Old Mar 20, 2002 | 09:01 PM
camaro6spd's Avatar
what is teh difference betweena mini spool and posi?
Old Mar 20, 2002 | 09:18 PM
I just put 3.70 gears in a week prior to the dismemberment of my carrier Is a spool just like a locker and if so what is involved in the installation. What is going to be the price on the new carrier? Everthing will be in the carrier that I need if I go that route right? Thanks for the help so far
Old Mar 20, 2002 | 10:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A differential contains a number of parts. 2 of them are the side gears. These allow the carrier to rotate when turning corners since the inside wheel is turning less than the outside wheel. A mini spool replaces these side gears and locks the axles together. Now when turning a corner both wheels try to turn the same speed. Since they can't the outside wheel will slip across the ground trying to catch up. There is no differential action with a spool or mini spool. A full spool replaces the entire carrier that the ring gear attaches to and locks both axles. It's much stronger than a mini spool.
Mini spools are used primaraly for dirt track racing where tire slippage isn't a big concern.
For any street use you should be using a posi or locker type carrier. A posi still allows differential action in turns by slipping the clutches but transmits power to both wheels during straight line acceleration.
Old Mar 21, 2002 | 11:01 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The mini spool works the same as a full spool, they positively lock the axles together. They are not recommended for street use and with either, you should run aftermarket axles.
The posi carriers I offer are complete brand new units and are $445. More info is on my page at www.9bolt.com
Miles
www.9bolt.com
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
IroczFan
Oct 6, 2015 10:13 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
