can i drive without the T.C. 4 prong connector plugged in???
Old Mar 31, 2002 | 03:46 PM
breathment's Avatar
I unplugged the connector a few days ago to see if that would stop the problem with the T.C. constently locking and unlocking when driving. and it did. so can i drive my car like this without it causing and problem? or should i stay off the highway??
Old Apr 1, 2002 | 03:12 PM
breathment's Avatar
top
Old Apr 1, 2002 | 07:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's probably not a good idea to drive for extended periods in O/D with it unplugged.
Old Apr 1, 2002 | 08:18 PM
breathment's Avatar
i try and stay off the highways as much as possible, usualy don't go over 45 MPH
Old Apr 1, 2002 | 09:02 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Not a good idea!!! Maybe ok for in town but on any highway use it will burnup the trans over time. I know because I did it and I fried my trans. I bought the GTA that had a engine fire and did not get the lockup wire hooked up properly and overheated the trans and trashed the planetary gears.
Old Apr 1, 2002 | 09:04 PM
breathment's Avatar
do u think its better then drivign it with it constently locking and unlocking?? i DO know that since i unlocked it, my gas millage has increased ALOT.... i need to know how to fix it
Old Apr 1, 2002 | 10:11 PM
jamesbern's Avatar
It can't possibly burn up your tranny because the only function is to lock up the converter. I have had mine unplugged forever and with no adverse effects. You should get it fixed if you don't have the tools and some knowledge about your tranny. If you do know enough to try it then you could either troubleshoot the problem, quite easy, or you could replace all the switches in your tranny. It sounds to me like your lockup switch, which is the one directly in the bottom of the pump at the front of the engine is gone bad. If you need more help feel free to ask. Good luck!!
Old Apr 2, 2002 | 07:40 AM
82camaro's Avatar
Car: 82 camaro SC
It can hurt the tranny because of the extra heat generated from the torque converter. In OD the rpms drop, but without the lock-up the converter slip constantly. Set-up a manual switch.
Old Apr 2, 2002 | 08:49 AM
a73camaro's Avatar
Re: can i drive without the T.C. 4 prong connector plugged in???
What is wrong with it locking and unlocking. It is suppost to do that. At part throttle cruise, it locks up. Give her a little more gas and she unlocks. Let off on the throttle, and it locks up.
Old Apr 2, 2002 | 02:35 PM
breathment's Avatar
because it locks and unlocks while at a constant speed. i can give it gas or let off the gas and it still does it... see my other post for more info
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
