700R4 question
Old Apr 1, 2002 | 01:06 PM
IROCZ88's Avatar
attn PROBUILT or anyone knowledgable, I have a 700R4 question
I found this on ebay...does it sound good to you guys?!?!? The bid is up to $560 and I am considering this instead of $1300 on a new probuilt. If I'd win this I will probably put in a transgo shift kit.
700R4 STREET PERFORMANCE TRANSMISSION. OUR 700R4 LEVEL ONE TRANSMISSION SELLS FOR $799.00 A REAL STREET PERFORMANCE TRANSMISSION FOR MODIFIED ENGINES UP TO 350 HP. THE CASE IS CLEANED WITH A SPECIAL PROCESS THAT LEAVES A NATURAL ALUMINUM FINISH. EACH TRANSMISSION COMES WITH A 30 SPLINE INPUT SHAFT. 10 VANE PUMP ROTOR ASSEMBLY. HARDENED HIGH REV PUMP RINGS. HEAVY DUTY 29 ELEMENT INPUT SPRAG. ALL NEW BUSHINGS. ALL NEW WASHERS. ALL NEW TORRINGTON BEARINGS. CORVETTE SERVO FOR CRISP SHIFTS. LARGER BOOST VALVES FOR FIRMER SHIFTS. INCREASED 3/4 CLUTCH HOLDING CAPACITY. EXTRA WIDE PERFORMANCE BAND FOR INCREASED HOLDING CAPACITY. INCREASED LUBRICATION. TRANS IS FULLY DYNO TESTED AND ROAD TESTED IN A CAMARO AND BACKED WITH A 6 MONTH WARRANTY.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
