99 10-Bolt swapped in for 86 Aussie 9 bolt
Old Apr 3, 2002 | 11:05 PM
86IROC-SS's Avatar
How much trouble to swap in the 4th gen rears on a thirdgen. I understand that the axles are longer so my tires will stick out more than they do. Has anyone done this swap and have pictures? Will my 3rd gen rims fit correctly with backspacing (i think that they will) The rear end is a 99 SS 10bolt with 3.23 gears, disc brakes, posi and TCS. I dont care about the TCS, i currently have a 4 wheel disc setup from the factory, i would like to retain 4 wheel disc, will the ABS on the 4th gen rear mess anything up, ways to bypass this? The rear end is a steal and i would like to replace this open POS i got right now. Will the 3rd gen driveshaft fit the 4th gen rear end? Thanks for any help i get in advance . Looking forward to posi launches in the future
Matt :lala:
Old Apr 3, 2002 | 11:12 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Hmmm, you've got an open diff 9 bolt eh? Where are you located? I might buy it from you.
Miles
www.9bolt.com
Old Apr 4, 2002 | 01:20 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
I've got a 85 posi 9-bolt that I'm swapping out for a 10-bolt. The 9-bolt has 4.10's in it. But I believe the carrier is about to die. posi is slipping and i found metal shavings in the fluid.
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theurge
Aug 21, 2015 12:46 PM
Bull86
Aug 10, 2015 05:43 PM
