Best tranny
Old Apr 6, 2002 | 08:19 PM
khellendros's Avatar
Best tranny
What would be a better transmission for a 350 TPI 5.7liter engine. I want a manual, and i know a T5 will hold up pretty nicly. Anything else besides that, that maybe will hold up a little bit better under heavy shifting? And if possible, please list price ranges? Thanks In Advance
Old Apr 6, 2002 | 09:58 PM
87 iroc L98's Avatar
I don't think that the t5 would be strong enough for a 350, thats why when chevy came out with the 350 in 87,they jamed in the 700R4 cause the t5 would nuke under the 350's torque.
If you want a manual tranny, check into a tranny called a t56.
BUT DON'T QUOTE ME ON THAT ONE>
Vance
Old Apr 6, 2002 | 10:40 PM
t56????
A T56?? What would that be out of, a 4th generation F-Body, and how well will that bolt up and with what difficulty?? Thanks....
P.S. : Isn't that a 6speed?
Old Apr 6, 2002 | 10:55 PM
BenDoe91z28's Avatar
Your options for a manual tranny are pretty much limited to 2 transmissions. The T-56 is a 6 speed taken out of a 4th generation Camaro/Firebird. You need to get all the parts from the donor car, then install them in yourse. The main problems people come into is you need to fabricate/buy stuff. You need a different crossmember, shorter drive shaft, and you need to modify your shifter hole. I think the ballpark price for this is going to be around $2000 if you do it yourself, and you get all the stuff USED(aka 40000 miles on it). The other option for the T-56 is the aftermarket T-56 which is more of a bolt in, but this will set you back $2300 and you still need to fabricate some stuff. Your second transmission is knows as the Tremec 3550. This transmission uses the same clutch, same driveshaft, you need to add spacers to the crossmember(two pieces of aluminum) and a different shifter. The other type of tremec is the TKO. The T-56 both aftermarket and production are rated to about 450 torque. The tremec 3550 is rated at 425 and the TKO is rated at 525. The tremec 3550/TKO will cost you about 2000/2300 accordingly. But of course it will be NEW. If your looking for an easy bolt in job, go with the tremec. If you feel a need for a double overdrive and like to fabricate your own stuff, go for the T-56. Search the message boards for more information on both swaps.
Old Apr 7, 2002 | 03:10 AM
87RS402's Avatar
Ben got everything right but the prices.
Aftermarket T-56 $1940
Tremec 3550 $1654
Tremec TKO $1854
It pays to do your homework.
The 3550 and TKO need a new bellhousing and the T-56 requires shorting the driveshaft and tq arm. All 3 come with shifters. Yes the T-56 is a 6 speed but it adds the ratio between where 4th and 5th are on the T-5 and extends the final OD ratio to .62 from the T-5's .68. Spohn makes a crossmember for both applications with or without tq arm mount.
Old Apr 7, 2002 | 04:15 AM
I was including in my estimates the prices of the extra goodies you get to buy, like shifters and stuff....
Old Apr 8, 2002 | 03:26 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Tremec 3550 $1654
Tremec TKO $1854
Who sells them at those prices. Any links?
Old Apr 8, 2002 | 03:54 AM
toosloz's Avatar
you dont need to shorten your driveshaft
Old Apr 8, 2002 | 10:25 AM
87RS402's Avatar
Pontimaniac, email or PM me and I'll hook you up with that information.
Old Apr 8, 2002 | 02:32 PM
xxwarrior36xx's Avatar
T-56 no questions man its an awesome underrated trans! Get it man...6spd
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
